Help with install Tips and Tricks
Old Feb 16, 2010 | 09:15 PM
bpd119's Avatar
bpd119
Default Help with install Tips and Tricks
I will be installing a vance and hines big radius 2 into 2 exhaust on my 2008 fat bob this week. I did a search but couldnt find anything on my model. i am sure this is pretty straight foward, but any tips or tricks you could give me would be excellent. thanks
Old Feb 16, 2010 | 09:19 PM
ghostrider69's Avatar
ghostrider69
Pretty straight forward. Just make sure you install new exhaust gaskets.
Old Feb 16, 2010 | 09:23 PM
bberck's Avatar
bberck
Keep lots of towels around me when doing exhaust. Put them anywhere I can to protect the finish.
I also wipe them done good with Alcohol before I start it up. I am not sure if this is needed on some of these new pipes but you could use to get fingerprints burned into the pipes the first time they got hot.
Old Feb 16, 2010 | 10:17 PM
HDDyna2006's Avatar
HDDyna2006
I wrapped my with plastic while getting them there,
I also sprayed gaskets with lubricant to get them in place,
your flange retaining ring should be ok, mine were lil rusty, new ones are .99 each, Torque flange nuts without heatshields,
use painters blue tape on any socket/extensions that might contact pipes/ heatshields. another set of hands might help.
Old Feb 17, 2010 | 03:14 AM
jmpancoast's Avatar
jmpancoast
There were similar quesions asked in a thread yesterday. Maybe some of the info will help you. Here is a link:
https://www.hdforums.com/forum/dyna-...ort-shots.html
Old Feb 17, 2010 | 06:53 AM
rounder's Avatar
rounder
it is a super easy exhaust to install. I recommend installing the heat shields and tightening them down before you install the pipes. I also recommend putting down a towel in case you accidently drop one of the nuts while installing the rear exhaust flange nuts. they can easily get lost in between the primary and engine and stuck there.
DamienBlade
Dec 17, 2014 10:22 PM
Clinton James Low
Aug 27, 2014 03:52 AM
sioux565
May 22, 2014 03:58 AM
roadrage12
Apr 19, 2014 03:52 PM
FireRyder09
Dec 2, 2009 10:49 AM
