Narrow, Mid, or Wide glide?
Old Feb 17, 2010 | 12:53 PM
SURFOR Chop's Avatar
SURFOR Chop
Marksman -
Pre-'06 FXD models (except FXDWG) have 39mm fork legs
Pre-'06 FXDWG have 41mm fork legs
'06-later models (including FXDWG) have 49mm fork legs
In '06 they discontinued the visor mounted headlight on Dyna models; but, continued its use with Sportsters ....
I am not sure what year the 39mm fork legs were introduced; but before that, there were 35mm fork legs on some of the earlier Super Glide and Sportster models ....
I believe '99 would have been a 39mm front end ....
What this means for most of you fellas is that if you have a pre-'06 FXD and want to go wide, you've got to either get special construction 39mm wide triple trees or change out the front end to go with 41mm fork legs ... I believe a 49mm front end could be adapted to pre-'06 as well ....
For '06 and later guys, you can just change to the Wide Glide triple trees and reuse your fork tubes ....
R/
'Chop
Old Feb 17, 2010 | 12:56 PM
thomaskray's Avatar
thomaskray
don't know if this helps...
here is my 2002 Superglide with the stock Narrow Glide 39mm front...
And here it is after the Wide Glide 49mm conversion...
Old Feb 17, 2010 | 01:06 PM
thomaskray's Avatar
thomaskray
If interested... a couple more. Keep in mind I changed alot more than the front end. But you can plainly see the difference in a 49mm wide vs. a 39mm narrow.
Stock:
after Wide Glide conversion: (same bike, I promise)
Old Feb 17, 2010 | 01:34 PM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by WS6 Formula
Here's a couple of before and after photos, (06 and up) Mid Glide/Wide Glide. Last photo below, left to right, Wide Glide, Narrow Glide, Mid Glide (06 and up Dyna's).
Old Aug 29, 2012 | 09:24 AM
BluBob's Avatar
BluBob
Does anyone have the specs for the center to center measurement of the mid vs. wide trees? I need to have some spacers made to go from mid to wide. I know it is about 1.4" difference, but I need an exact spec to have the disk spacer and wheel spacers made.
Old Aug 31, 2012 | 02:30 PM
teezee1967's Avatar
teezee1967
Stage IV
Does anybody know if a dyna front end will fit on my sportster
Old Aug 31, 2012 | 06:37 PM
Tat2u's Avatar
Tat2u
Fat bob has same width trees as wide glide but without the extra rake that the wide glide has
Old Aug 31, 2012 | 07:25 PM
Dirknar's Avatar
Dirknar
Originally Posted by Marksman
Yep. Clearly my 99 FXD is like the narrow glide on the right.
Wow the mid looks a lot wider.
I assume the tubes are smaller on the older Narrow glides?
So if I wanted to change things, I would need new tubes in addition to the trees?
Thanks
Yep.. Do it, I upgraded my narrow to a mid and I love it. It looks right and not like a sportster front end stuck on a big twin. I got the 06' street bob midglide Trees/tubes/lowers from ebay for 400.00. You need a new midglide wheel and fender too.. Sold my narrow glide stuff and almost paid for the whole swap.
Old Sep 22, 2014 | 07:56 PM
Johnnyh14's Avatar
Johnnyh14
Default Narrow glide,
To get back in the wind, I found a sweet 2003 dyna in great shape i could afford. I don't like the Sportster front end. I do like the dual side by by side lighting available for the narrow forks. Should I sell the bike or get the wider front end for this one when I find one. The dynas handle so much different than my softtail. Johnny
Old Sep 22, 2014 | 08:07 PM
Johnnyh14's Avatar
Johnnyh14
Originally Posted by red devil
uneasy, you have mid glide trees stock & Marksman, you are running narrow glide.
Sorry but I really like your bike sitting out on the deck. Sorry if this is is the wrong place to post. Johnny
