mid glide trees. triple trees. wtf?
pics would be nice. along with prices....
sorry if this is a stupid question. but its worth being the idiot.
Dynas models, prior to 2006, had two different style front ends. \\; \\;The Wide Glide models had a wider front end meaning the tubes were further apart. \\; The other Dynas had a narrow glide front end, same as the Sportsters. \\; The tubes were much closer together.
Starting in 2006, the Dyna line lost the narrow glide front end and went to the mid-glide on all models except the Wide Glide. \\; The mid glide front end tubes were further apart than the old narrow glides, but closer together than the wide glides.
Each of the newer Dyna models were set up with different amounts of rake in their front end. \\; This rake is accomplished two ways\\; \\; either in the neck of the frame and/or in the triple trees, which hold the tubes.
Super Glides, Street Bobs (mid glide front end) \\;- \\;29 degrees in the neck, 0 degrees in the trees = 29 degrees total rake
Lower Rider (mid glide front end) - 29 degrees in the neck, 1.5 degrees in the trees = 30.5 degrees total rake
Wide Glide - (wide glide front end) - 32 degrees in the neck, 2 degrees in the trees = 34 degrees total rake
Fat Bob - (wide glide front end) - 29 degrees in the neck, 0 degrees in the trees = 29 degrees total rake
I hope this will address your question.
Dynas models, prior to 2006, had two different style front ends. \\;\\\\\\; \\;\\\\\\;The Wide Glide models had a wider front end meaning the tubes were further apart. \\;\\\\\\; The other Dynas had a narrow glide front end, same as the Sportsters. \\;\\\\\\; The tubes were much closer together.
Starting in 2006, the Dyna line lost the narrow glide front end and went to the mid-glide on all models except the Wide Glide. \\;\\\\\\; The mid glide front end tubes were further apart than the old narrow glides, but closer together than the wide glides.
Each of the newer Dyna models were set up with different amounts of rake in their front end. \\;\\\\\\; This rake is accomplished two ways\\\\\\; \\;\\\\\\; either in the neck of the frame and/or in the triple trees, which hold the tubes.
Super Glides, Street Bobs (mid glide front end) \\;\\\\\\;- \\;\\\\\\;29 degrees in the neck, 0 degrees in the trees = 29 degrees total rake
jmpancoast, thanx for the explanation!
roadman, i shot a tic today just for you! (troops in contact)
Wide Glide - (wide glide front end) - 34 degrees in the neck, 2 degrees in the trees = 36 degrees total rake
Thanks for the correct info WS6 Formula. \\; \\; \\; [sm=thanx.gif]
is there anybody out there that has pics so that i could compare the before and after?
thanx
