mid glide trees. triple trees. wtf?
Old Jun 7, 2008 | 03:54 PM
blavis's Avatar
blavis
Default mid glide trees. triple trees. wtf?
can somebody please explain what the heck this exactly is and the differences/advantages of every style?!?!?
pics would be nice. along with prices....
sorry if this is a stupid question. but its worth being the idiot.
Old Jun 7, 2008 | 11:03 PM
Roadman56's Avatar
Roadman56
Default RE: mid glide trees. triple trees. wtf?
Can't give you much info on the triple trees. It depends what you want to do to your ride. I will say lob a few rounds out there for me&nbsp\\;and keep up the good work.
Old Jun 8, 2008 | 07:02 AM
jmpancoast's Avatar
jmpancoast
I hope this will address your question.
&nbsp\\;
Dynas models, prior to 2006, had two different style front ends.&nbsp\\;&nbsp\\;The Wide Glide models had a wider front end meaning the tubes were further apart.&nbsp\\; The other Dynas had a narrow glide front end, same as the Sportsters.&nbsp\\; The tubes were much closer together.
&nbsp\\;
Starting in 2006, the Dyna line lost the narrow glide front end and went to the mid-glide on all models except the Wide Glide.&nbsp\\; The mid glide front end tubes were further apart than the old narrow glides, but closer together than the wide glides.
&nbsp\\;
Each of the newer Dyna models were set up with different amounts of rake in their front end.&nbsp\\; This rake is accomplished two ways\\;&nbsp\\; either in the neck of the frame and/or in the triple trees, which hold the tubes.
&nbsp\\;
Super Glides, Street Bobs (mid glide front end)&nbsp\\;-&nbsp\\;29 degrees in the neck, 0 degrees in the trees = 29 degrees total rake
&nbsp\\;
Lower Rider (mid glide front end) - 29 degrees in the neck, 1.5 degrees in the trees = 30.5 degrees total rake
&nbsp\\;
Wide Glide - (wide glide front end) - 32 degrees in the neck, 2 degrees in the trees = 34 degrees total rake
&nbsp\\;
Fat Bob - (wide glide front end) - 29 degrees in the neck, 0 degrees in the trees = 29 degrees total rake
Old Jun 8, 2008 | 05:38 PM
blavis's Avatar
blavis
ORIGINAL: jmpancoast
&nbsp\\;\\\\\\;
Dynas models, prior to 2006, had two different style front ends.&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;The Wide Glide models had a wider front end meaning the tubes were further apart.&nbsp\\;\\\\\\; The other Dynas had a narrow glide front end, same as the Sportsters.&nbsp\\;\\\\\\; The tubes were much closer together.
&nbsp\\;\\\\\\;
Starting in 2006, the Dyna line lost the narrow glide front end and went to the mid-glide on all models except the Wide Glide.&nbsp\\;\\\\\\; The mid glide front end tubes were further apart than the old narrow glides, but closer together than the wide glides.
&nbsp\\;\\\\\\;
Each of the newer Dyna models were set up with different amounts of rake in their front end.&nbsp\\;\\\\\\; This rake is accomplished two ways\\\\\\;&nbsp\\;\\\\\\; either in the neck of the frame and/or in the triple trees, which hold the tubes.
&nbsp\\;\\\\\\;
Super Glides, Street Bobs (mid glide front end)&nbsp\\;\\\\\\;-&nbsp\\;\\\\\\;29 degrees in the neck, 0 degrees in the trees = 29 degrees total rake
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
ahhhh.... i see. i think i do anyways. im gonna assume that switching to the wide front end will cost some $$$$$$? are the result just for looks or is there a noticable difference?
jmpancoast, thanx for the explanation!
roadman, i shot a tic today just for you! (troops in contact)
Old Jun 9, 2008 | 05:24 AM
jmpancoast's Avatar
jmpancoast
WS6 Formula PMed me and explained&nbsp\\;the specs I posted on the Wide Glide rake were inaccurate.&nbsp\\; Here are the correct specs:
&nbsp\\;
Wide Glide - (wide glide front end) - 34 degrees in the neck, 2 degrees in the trees = 36 degrees total rake
&nbsp\\;
Thanks for the correct info WS6 Formula.&nbsp\\;&nbsp\\;&nbsp\\; [sm=thanx.gif]
Old Jun 9, 2008 | 03:27 PM
blavis's Avatar
blavis
is there anybody out there that has pics so that i could compare the before and after?
thanx
Old Jun 9, 2008 | 04:16 PM
jmpancoast's Avatar
jmpancoast
You can go to Harley's site and pull up the 360 walk-a-round view for the Sportster, Super Glide, and Wide Glide to see the differences.
Old Jun 9, 2008 | 05:56 PM
ryda's Avatar
ryda
ORIGINAL: blavis
thanx
Here is the Fat Bob triples next to the Street Bob.....
Old Jun 9, 2008 | 06:47 PM
WS6 Formula's Avatar
WS6 Formula
Here's a couple of before and after photos, (06 and up) Mid Glide/Wide Glide. Last photo below, left to right, Wide Glide, Narrow Glide, Mid Glide (06 and up Dyna's).
Fat Chance
Jun 15, 2014 05:27 AM
mturner2003
Feb 3, 2014 06:40 AM
jettchoppers69
Jan 7, 2013 09:46 PM
sothai
Dec 3, 2012 05:29 AM
ebeattie
Jul 17, 2008 08:28 PM
