Rear wheel install problem
Old Feb 18, 2010 | 06:00 PM
bberck's Avatar
bberck
Default Rear wheel install problem
I got my rear tire mounted to my new wheel today. This is a HD wheel with HD spacers made for the Dyna but the rotor is rubbing the inside of the bracket for the brake caliper.
My solution is to shim the brake rotor out to get it back center with the bracket.
Thoughts suggestions ETC.
Old Feb 18, 2010 | 07:29 PM
lilspanky's Avatar
lilspanky
are the spacers different sizes if so try switching them around. Just a thought. if not Shim the crap out it and forget it.
Old Feb 18, 2010 | 09:19 PM
bberck's Avatar
bberck
The spacers are different sizes but way to different to swap them around.
I got the shims in behind the rotor and it seems to be ligned up. I am to tired to mess with it any more today so going to wait till tomorrow with some fresh eyes.
Old Feb 18, 2010 | 09:22 PM
OutlawBagger's Avatar
OutlawBagger
Best thing. Take a break and try it with a cool head. It will be worth it in the end.
Old Feb 18, 2010 | 10:29 PM
lilspanky's Avatar
lilspanky
+1 on that. Walk away for lil and take a break. Im begining to think they gave you the wrong spacers which would make your bike travel sideways down the road. wish I could be of more help
Old Feb 18, 2010 | 10:41 PM
fixxr's Avatar
fixxr
You can try it without the brake pads to get an idea how much room you will need.Be sure to put some tape on your wheel so you don't get any unwanted BOO-BOO's!
Old Feb 19, 2010 | 07:03 AM
bberck's Avatar
bberck
I measured the spacers and they are they exact same as the stock spacers.
I dont have the caliper mounted yet. The bracket the holds the caliper is what is rubbing the rotor.
Old Feb 19, 2010 | 07:43 AM
rounder's Avatar
rounder
got a picture of this?
Old Feb 19, 2010 | 10:45 AM
bberck's Avatar
bberck
First picture shows the bracket that is rubbing. It is making contact on the inside.
Bad picture of inside
Old Feb 19, 2010 | 10:55 AM
rob_will's Avatar
rob_will
are you using the shorter spacer on the side with the brake caliper? Just wondering
