Lowering the front end (part2)
PICS https://www.hdforums.com/forum/dyna-...drag-bars.html
I never felt any ill effects and I've had this sucker up to almost 75 mph.
This is a very common technique on sport bikes, although generally most would only change them by 1/16" at a time.
I have raised the rear of my 07 FWD by 3/4" with taller rear shocks (this has the same effect as lowering the front), and raised the tubes maybe 1/16".
Under full throttle acceleration, at around 90-95 (dragging a new vette) it started a gentle back and forth sway. Not a head shake, but I didn't stay in the throttle to see what might have happened. Now if I want to go that fast I take the Street Rod.
On some bikes, if you raise the tubes too far, the lower triple tree will hit the front fender under hard/abrupt braking (e.g. my Street Rod).
I would try it, but not an inch at a time. Put a jack under the frame so it doesn't drop too far when you loosen the pinch bolts.
link: https://www.hdforums.com/forum/dyna-...mods-pics.html
