Lowering the front end (part2)
Old Feb 24, 2010 | 08:07 PM
gregbenner's Avatar
gregbenner
Exactly the same. It is critical to keep in mind that we are NOT changing the height of the rear of the bike. Therefore, if you lengthen or shorten the fork length, you change the angle of the forks to the ground even though you don't change the neck angle. Imagine if you had 6 feet long forks with the same rear shocks and rear height. This would tend to extend the forks forward..increasing the trail. Don't assume the rear and the front stay horizontal. If they were exactly horizontal before you change the forks, they will now be at an angle however slight..either up or dowm depending on whether you raise or lower the fork tubes.
Hope this makes sense. I wish I could draw pictures, or just write better.
Look at the attached article
http://www.sportrider.com/tech/146_0310_art/index.html
perhaps this will clarify
Originally Posted by jstreet0204
The only definition I have heard for trail is the following, which is obviously different than what you are refering too.
Old Feb 24, 2010 | 08:45 PM
jstreet0204's Avatar
jstreet0204
Originally Posted by gregbenner
Exactly the same. It is critical to keep in mind that we are NOT changing the height of the rear of the bike. Therefore, if you lengthen or shorten the fork length, you change the angle of the forks.
If you change the angle of the forks by raising or lowering the forks, as you describe, the trail will change.
If you read my second post I said assuming you keep the bike level. If you are only lowering the front then yes it would change trail even if there is no rake in the trees, but why would anyone just lower the front. Most of the time this question is posed by someone who has lowered the rear and wants to lower the front to even it up.
Old Feb 24, 2010 | 09:02 PM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by Yldtang
I saw in the other topic about sliding the tubes up the trees about an inch. Has anyone here done this and if so what are the cons? Does it decrease the turn radius or increase the chance of high speed wobble? I don't want to lower the entire bike as my wife rides a lot. Any input would be appreciated and pictures would be nice. My bike is a 08 street bob. Thanks
I don't get it...
Old Feb 25, 2010 | 06:01 AM
gregbenner's Avatar
gregbenner
Yikes, didn't catch that. I think we come from different backgrounds...in my experience the only reason someone would lower the front is to change the handling (i.e. "trun in" of perhaps headshake) by changing the trail. Not really used to situations where someone would want to lower the entire bike. Sorry for the confusion
greg
UppercaseJC
Apr 27, 2017 03:52 PM
wilddave
Sep 24, 2015 07:59 AM
jamesrgarner
Sep 9, 2009 07:31 AM
CRF
Oct 10, 2008 11:36 PM
urdollar
Apr 1, 2008 03:04 PM
