need to decode a VIN
Old Jul 27, 2006 | 07:34 PM
dart65's Avatar
dart65
4th Gear
Default need to decode a VIN
Hello
I would like to know what this VIN means:
1hd1gel1xty321432
thanks
Old Jul 27, 2006 | 07:43 PM
bobcowan's Avatar
bobcowan
Default RE: need to decode a VIN
Decode
The 5th and 6th letters designate the model. GE = FXDWG
Old Jul 27, 2006 | 11:46 PM
soup48's Avatar
soup48
If you have the owners manuel it should be in the front section.
Old Jul 28, 2006 | 10:34 AM
Mrkicks's Avatar
Mrkicks
Using the search feature, you would find this:
Harley VIN Numbers
How to Identify Harley VIN Numbers
When buying any used Harley-Davidson, checking the Harley VIN numbers against the title is mandatory. If they do not match exactly you should think about looking elsewhere. Typographical errors on motorcycle registrations are sometimes very common, but don't take any chances. In some cases a visit to your local department of motor vehicles may be enough to get a VIN typo corrected. However, when buying a Harley or other vehicle with an out of state title, the difficulty in correcting such errors increases dramatically. With strict state regulations increasing every year, you are better off avoiding any problem that may leave you holding a piece of property that cannot be documented. Not only is it illegal to drive, but you leave yourself open to unscrupulous people who could make a legal claim against you and your property.
If you have a Harley engine with matching title taken from a crashed or salvaged motorcycle, and put that engine into a new frame, the title is invalid. Anyone trying to sell you a post-1970 Harley where the title VIN only matches the engine, but does not match the number on the frame, PASS! Want to upgrade your bike to a new custom frame? You must apply for a new title. While it is nice to have an original Harley with matching engine and frame numbers, only the frame VIN is relevant when it comes to legal registration.
Never accept a Harley or other vehicles without a legal title. One such case involved an individual restoring a Harley originally purchased without proper papers. Some deadbeat and his lawyer came along and claimed the Harley was his. Without enough money to pay an attorney, and lacking any legal title or receipts, the poor guy was forced to give the bike to this shark in order to avoid a lawsuit. This may sound like extortion but it happens all the time. Don't become another horror story. Take precautions when investigating the authenticity of the Harley VIN and registration.
There has always been much debate over bikes with matching numbers and their true value. In my opinion, any Harley being sold as "rare" or "limited" is usually anything but that. As with beauty, value and rarity are often in the eye of the beholder. If matching numbers makes a motorcycle more valuable to you, then only you can put a value on it. Just don't expect the next person buying that Harley from you to think the same way.
Locating the Harley VIN
Prior to 1961
On Harley models prior to 1961, the engine number acts as the VIN. This number can be found on the left side engine case. Harley models produced prior to 1969 do not carry any frame number.
VIN Numbering Conventions:
First two numbers are the model year.
Letters (up to four) are the model designation.
The last numbers are the production run number.
1962 - 1969
Letters (2-4) are the model designation.
In addition, models with 4 digit production numbers have an even-numbered first digit for even years, odd for odd years.
Models containing a 5 digit production number will have the first two digits even for even years, odd for odd years.
Why is this important? If the VIN does not follow this even or odd numbering sequence, you can almost guarantee that the VIN has been altered. It is extremely common to find mismatched engines in these early bikes with different VIN numbers than the title paperwork.
1970 - 1980:
Beginning in 1970, Harley started stamping VIN numbers on both the frame and engine case. The exception as noted by our friends at Cyborg Cycles, is the 1979 model. This exception is discussed below.
First two numbers are the model code.
Next 5 digits, position 3-7 is the production run number.
The last 2 digits designate the
Old Jul 28, 2006 | 06:26 PM
WgSkee's Avatar
WgSkee
Mrkicks... Good job man... If anyone thinks they can get away with hot #'s... Good Luck... the VIN Patrol at any event will impound your bike in a heartbeat... Even if you are innocent you'll lose everything.... Ain't worth it, those cheap parts carry a heavy price in the long run.... Thanks again Mrkicks... Whew that's ALOT of typin'..LOL..
deallangary
Oct 20, 2013 11:54 PM
SECOLORADO
Jun 11, 2013 08:39 PM
J Kryk
Jul 27, 2012 02:46 PM
HDF Tech
General Topics/Tech Tips
Nov 3, 2009 09:25 AM
JACKO
Shovelhead
Mar 21, 2006 05:20 PM
