Riser for Fat Bob Apes
Old Feb 24, 2010 | 09:43 PM
nazareth27's Avatar
nazareth27
yepper hignight i still have them, drop me a pm anytime
Old Feb 24, 2010 | 09:45 PM
hogcity5's Avatar
hogcity5
naz,
I think what your getting at is that your concerned that the diameter of your stock risers are so much bigger than the set you ordered...correct? I think they will be fine its just that your stock ones are fatter than the normal risers. I also think the riser bolt will prob fit your new risers also. If you have the harley poly bushings the riser base will sit on top of the chrome washer attached to the bushing. Hope this helps.
Old Feb 24, 2010 | 09:46 PM
s_hignight's Avatar
s_hignight
Default cycle shack pipes
how much will you take for them, i think i will take em off your hands, i have an 09 fatbob and i need some improvement over my stock exhaust. for some reason i cant pm on here it tells me im not allowed.
Old Feb 24, 2010 | 10:04 PM
nazareth27's Avatar
nazareth27
that helped a lot hogcity, yep thats the answer I was looking for. Thank you very much! My bushings didnt come from harley but they are the polyurethane, from j and p when I ordered the risers. Thank you!!
The cycle shacks are $100 dollars even, Ill cover the shipping. Unless you happen to be halfway across the planet of course. Id be glad to get them somewhere where theyll be used. I can get you photos too also.
Old Feb 24, 2010 | 10:06 PM
nazareth27's Avatar
nazareth27
Ill post some results when I get hte job done, I ordered the apes on just this last Sunday, im not expecting them for another week or so maybe, not sure, but ive heard good things on hill country cycles but did learn the shipping takes a while.
Old Feb 24, 2010 | 10:08 PM
s_hignight's Avatar
s_hignight
yah i will definately take them, did they sound pretty good?I live in paris tx, how do you want to do the transaction?
Old Feb 24, 2010 | 10:42 PM
s_hignight's Avatar
s_hignight
call me at 903 268 8901 Sam
Old Feb 24, 2010 | 11:11 PM
s_hignight's Avatar
s_hignight
can you ship them tomorrow?
Old Feb 25, 2010 | 12:21 AM
fxd650's Avatar
fxd650
wild1's makes a super clean an beefy 1.25 riser for 1 inch bars, and you'll need a top clamp too...
Old Feb 25, 2010 | 12:33 AM
HOGKID84's Avatar
HOGKID84
Originally Posted by SC-Longhair
Put whatever size riser you want to put on. There is no law stating maximum or minimum height. Personally, I wouldn't go much taller than 2"-2.5".
I like your avatar pic
