Battery Questions
Old Mar 5, 2010 | 05:43 PM
srmason's Avatar
srmason
6th Gear
Default Battery Questions
I've owned a 09 Street Bob about 1.5 months and every time the bike sits 4-6 days without being rode the battery is dead. Is this normal?
I've previously owned an 07 sportster for a year and never had to charge or use a battery tender and sometimes didn't ride the bike for a couple of weeks.
So I just want to know if this is normal and should I pony up and get a battery tender or does this sound like some other type of problem?
I've replaced the battery in the street bob so I'm pretty sure the battery isn't the problem.
I'm just wondering if this is normal or the sign of some other issue.
Thanks!
Old Mar 5, 2010 | 05:48 PM
8541hog's Avatar
8541hog
You have a problem. I would start with checking all your connections, make sure they are clean and tight.
Do you have any electrical accessories wired to the battery, or is it all stock?
Old Mar 5, 2010 | 05:53 PM
wescoot2's Avatar
wescoot2
Nope, doesn't sound normal at all. If I were yu, I would check to make sure that your battery is getting the proper charge. You may be having a problem with your regulator or stator.
Old Mar 5, 2010 | 06:05 PM
godjunior's Avatar
godjunior
Doesn't sound normal at all. Not the bike expert here but should stand for much more than that even if you have the alarms system ON. My bike went for 4 weeks with the alarm on and when I went to start here up she just fired away. Like 8541 said I would check connections or as wescoot said, check that it is chargeing correctly.
Old Mar 5, 2010 | 07:43 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Check your battery connections,Check voltage while idling and at 2,000 rpms. voltage 12.8-13.2 v and 14.2-14.4 respectfully. Being EFI your voltage maybe 14.2 at idle. Also what are your riding habits? Very short rides, less than 30 minutes, may n ot be a sufficient charge and all you are getting is what's called a surface charge. If that's the case then a smart tender may be your fix.
Old Mar 6, 2010 | 03:03 PM
srmason's Avatar
srmason
6th Gear
This is the third battery I've tried on this bike. So I'm pretty sure that it's not the battery that is the problem. No accessories attached to the bike. I have a multimeter and the battery was reading 12.8v-12.9v fully charged which is about right and bike was showing 14.34v across the battery while running today at idle. I think something is shorted or something. I'm heading over to my mechanic buddy hopefully this evening to check the alternator and then we are going to check the amperage while not running.
Old Mar 6, 2010 | 05:10 PM
8541hog's Avatar
8541hog
Sounds like you have something that is not turning off and draining the battery. If you are getting those voltages it doesn't appear to be a charging issue.
One way you can prove it, Disconnect the battery at night or for a few days and see if you still have the problem.
Old Mar 6, 2010 | 05:48 PM
bigdaddy33's Avatar
bigdaddy33
'09 SB, you've owned it 1.5 months, and you're on your 3rd battery. Yeah, I'd say there is something wrong!
RoadKingAnni562
Electrical/Lighting/Alarm
Apr 25, 2018 02:31 PM
Redd-Rider
Jan 28, 2017 11:49 AM
xl8832007
Feb 12, 2014 05:32 PM
MattFXDB
Apr 11, 2012 09:27 PM
eagle1
Dec 12, 2008 08:43 PM
