Sears red jack modification
Old Mar 5, 2010 | 08:47 PM
Vinsil's Avatar
Vinsil
Very cool Vic! Thanks for sharing, I have the same jack and going to follow suit.
Old Mar 5, 2010 | 08:56 PM
rdondes's Avatar
rdondes
I have the Sears Yellow jack. The pads are not bolted on. The rubber pads are integral to the lift arms. Then, in these pads, are holes (2 in each lift pad) into which there are lift pad risers (for lack of a better term) that give you additional height for something like an ATV or something. After I saw your mod, I wanted to see if the same thing could be done to my Sears yellow jack.
Here is a picture of this jack from the Sears website. There is nothing to unbolt. Here's the Yellow Jack: http://www.sears.com/shc/s/p_10153_1...echanics+Tools
Old Mar 5, 2010 | 08:58 PM
maddghost's Avatar
maddghost
Nice one Vic,good job,peace out!
Old Mar 5, 2010 | 09:02 PM
Grind's Avatar
Grind
Awesome, Vic. Wondering, though, how will this affect the ability to lift a Sportster? (Wife has one)
Old Mar 5, 2010 | 09:06 PM
SC-Longhair's Avatar
SC-Longhair
My dad taught me long ago... "The impossible can be done. Difficult takes a little longer."
Looking at that photo it doesn't look like that jack is a candidate for modding unless you have some welding skills and a cut-off wheel.
Old Mar 5, 2010 | 09:10 PM
SC-Longhair
Sorry I can't answer that because I don't have a sporty to test it on, meaning I don't even know anyone with a sporty. Is the frame irregular like the Dyna?
Old Mar 5, 2010 | 09:14 PM
Grind's Avatar
Grind
It's not irregular like the Dyna. I'm concerned about the width. What is it from outside to outside and inside to inside? If it'll still fit her Sporty, I'm getting some bolts tomorrow.
Old Mar 5, 2010 | 10:08 PM
SC-Longhair
Here ya go...
Out to Out: 19" In to In: 13.5"
Overall difference: 5.5"
Each lift pad: 2.75" wide.
In theory, I suspect the sporty would become more stable on the lift with it's wider stance. Hope it works out for ya.
Down with those damn h-d lift adapters!
Old Mar 5, 2010 | 10:10 PM
jstreet0204's Avatar
jstreet0204
I did this with my jack a few weeks ago. I have a jack from Northern Tool. I only had to do one side to make it clear, and it feels much more stable now.
Old Mar 5, 2010 | 10:17 PM
SC-Longhair
Originally Posted by jss1975snow
Oh man, I was hoping for less than 3.5" 2x6's get old after awhile.
I took some measurements.
Floor to the top of the rubber pad: 5 1/8"
With the oem wheels, there is 3/4" clearance between floor and bottom of the jack. Smaller wheel = lower overall height. Wheels can be had at Tractor Supply (I love that store), Harbor freight, lowe's, home depot,etc.
You could also drill new holes in the lift adapters to lower them. There is about 1/2" - 3/4" to be gained.
All of these mods are still much cheaper than the j&s or pitbull. Who doesn't like taking something and making it better?
Wheel change: -1/2"
Drill new holes: -3/4"
It seems in theory you could gain ~1.25" bringing overall height down to approximately 3 7/8". That's a difference of 3/8". If you crank your shocks up one setting, you could possibly gain that.
