Sears red jack modification
Old Mar 15, 2019 | 11:07 AM
  #741
barneyboy's Avatar
barneyboy
Originally Posted by TerryMcQ
Somebody steered me to your post of the jack modification. I don't have a Sears jack, I have harbor freight and pittsburgh. So while the video makes complete sense on how to do the mod, I need to know the new measurements from inside the jack pads to inside the jack pads and from outside the jack pads to outside the jack pads in case the tube steel the pads are currently mounted on are different dimensions and/or the pads are wider or narrower from my jack compared to your Sears red jack. I hope you are still on here 9 years later to answer! Thanks in advance for your help.
You should be able to determine the modded measurements using your own jack. Measure the distance between the outsides of the uprights that the pads are currently mounted on. This would be your modded pad to pad inside width. Add to that the width of your pad times two. This would be your modded pad to pad outside width.
Old Mar 15, 2019 | 11:22 AM
  #742
TerryMcQ's Avatar
TerryMcQ
My jack might have different dimensions than yours or others. I need to know the dimensions that work so I can make mine the correct width and buy the right amount of spacers when I get my hardware to make it fit the same as a jack that might have wider or narrower overall width to begin with..
Old Mar 15, 2019 | 11:32 AM
  #743
barneyboy's Avatar
barneyboy
Read post #28 in this thread.
Old Mar 15, 2019 | 01:01 PM
  #744
cggorman's Avatar
cggorman
This thread has covered nearly every variation possible. Just gotta sift thru it.
Old Mar 15, 2019 | 02:48 PM
  #745
John CC's Avatar
John CC
I don't know if this is the answer to your question, but I have a red sears jack and I just measured it. The rails are 13 1/2" outside to outside, and the pads are a touch over 2 3/4" wide, so if you move them to the outside of the rails they'd be 13 1/2" inside and 19+" outside.
Synstars
Oct 26, 2019 11:34 AM
jphillips
Mar 3, 2014 07:08 PM
rdondes
Mar 17, 2010 01:43 PM
davedyna
Oct 24, 2008 08:24 PM
Muddyape
Dec 9, 2007 11:36 PM
