Black primary cover: need help
Old Mar 6, 2010 | 04:26 PM
PG13125's Avatar
PG13125
Question Black primary cover: need help
After painting my lower front legs in black using epoxy paint, i want to paint my primary cover in black.
What should I use to do that? (type of paint, ...)
Thank you
Old Mar 6, 2010 | 05:01 PM
JunkHead's Avatar
JunkHead
The primary does get hot from the engine so you will need high heat paint. I just changed out all 3 of my covers with black ones from ebay for cheap. I got the primary for 40 bucks shipped, then i just painted the other half of it with high heat bbq paint flat black to match.
Old Mar 6, 2010 | 05:06 PM
PG13125's Avatar
PG13125
Old Mar 6, 2010 | 06:55 PM
Taddeoeg's Avatar
Taddeoeg
Depends on the exact look you're going for. HD has two engine black paints - textured and wrinkle. Your inner primary is probably texture, tho I can't swear to that on your bike. It is on my 07 SB and my gfs 00 Lowrider.
I used texture and then some chrome metallic and clear coat (rattle can all) to paint the a/c cover in this thread:
https://www.hdforums.com/forum/dyna-...a-c-paint.html
Old Mar 6, 2010 | 07:45 PM
Sonny's World's Avatar
Sonny's World
Maybe a black derby cover of some sort would be a satisfactory and cheaper alternative.
Old Mar 6, 2010 | 08:21 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Powder coat it. Get in touch with JRK5892 (Joe) on here. He will powder coat anything then you don't get the heat or peeling paint issues.
Old Mar 6, 2010 | 08:46 PM
JunkHead's Avatar
JunkHead
Originally Posted by PG13125
I knew you would say that. Neither this site or my photobucket will let me upload pics today. Ill try later and put some on for ya.
Old Mar 6, 2010 | 11:24 PM
chad peterson's Avatar
chad peterson
I agree, if ya got a few extra bucks...powder it & be done! Hook up with Joe, from what I see he's A+ quality & service!
Old Mar 7, 2010 | 01:41 AM
JunkHead's Avatar
JunkHead
You cant tell the color difference in person, but the camera flash shows it. but the inner primary flat black matches the engine fins.
Old Mar 7, 2010 | 01:26 PM
combat_doc's Avatar
combat_doc
Thank you
front forks look great id like that for mine did you remove em to paint?
