Saddle Bag Modification.
Old Mar 9, 2010 | 11:31 AM
CRZYLGZZ's Avatar
CRZYLGZZ
Default Saddle Bag Modification.
Hey guys. I've been digging through the "under 50" and the How to threads, and I'm at a. Loss.
Lemme explain, I have a set of Nylon throwover saddlebags. That are scratching my rear fender.
In my readings, I've seen Brackets that can be mounted onto my saddlebags so that I can convert them to Mounted and easily removeable.
Can someone post a thread, link, something to ease my searching frenzy. Any Help will be appreciated.
Old Mar 9, 2010 | 11:45 AM
BoomerBob's Avatar
BoomerBob
Yep. Throwover bags are known for scratching up rear fenders.
Best bet would be to get some bolt on bags and use Easy or Edge Brackets if they aren't HD brand or some other brand with their own mounting system.
I had some throwovers on a Dyna last year that didn't hit the fender because I had a detachable back rest on it. It kept the bags from touching the fender.
There are some fixed brackets available that are similar to the one pictured below.
These happen to be from Drag Specialties.
Old Mar 9, 2010 | 02:11 PM
SC-Longhair's Avatar
SC-Longhair
Hmm...what if you got creative. cut up some plastic and make the backside of the bags rigid. You could then get one of the detachable setups mentioned previously and have cheap detachable saddlebags. You could get the plastic, maybe 1/4"-3/8" thick at Tractor Supply Store, harbor freight (I think), or maybe Lowe's/Home Depot.
Could rivet it into the bag so that there are no bolt heads sticking out, would minimize scratching potential.
I don't know...I'm just thinking out loud here.
Old Mar 9, 2010 | 02:29 PM
CRZYLGZZ's Avatar
CRZYLGZZ
SC..that's exactly my Idea. Holes big enough to mount to the Docking Rails. Eliminate the throw over concept all together. I know there was a ez bracket setup for sale somewhere.. But I can't find it anywhere..
SC I'm not that creative.. But Ill go to Lowes and do a Lil Researching.
If you happen to run across an idea. Please, by all means. Tell me.
Old Mar 9, 2010 | 02:45 PM
SC-Longhair
I think I'd look at ABS plastic. Not lexan or acrylic.
Old Mar 9, 2010 | 02:52 PM
CRZYLGZZ's Avatar
CRZYLGZZ
ABS plastic isn't hard to fabricate. Just gotta get a concept.. I'm no mechanical engineer. So it'll be a project for me to do this.
Old Mar 9, 2010 | 04:41 PM
Taddeoeg's Avatar
Taddeoeg
http://www.easybrackets.com/
Old Mar 9, 2010 | 04:51 PM
mikel61101's Avatar
mikel61101
What I did was drilled two holes in my detachable sissy bar and and drilled two matching holes in my bags then put a 1/4" flat peice of metal inside and out that gave stability to the bags then put one vertically to keep them from flapping and/or hitting the nut when I ride 2up... used a couple chrome bolts to attch and presto when I take my sissybar off the bags come with it... Works great I think it looks good as you can't see any bars just the chrome bolt heads on the inside of the sissybar hardware... doesnt touch and holds A TON of wieght...
Old Mar 9, 2010 | 05:00 PM
CRZYLGZZ's Avatar
CRZYLGZZ
If i only had a detachable sissy bar set up.
(sigh)
Old Mar 9, 2010 | 05:19 PM
godjunior's Avatar
godjunior
I made my own Backplate for the saddlebags using the original bolt holes and the flasher. Got a machinist to make me a stainless steel spacer to go over the bolt. Bolted my bag with to the aluminium plate that I had made and voila, bolt on bags.
