Serviceing of 07 FXDC
ft/lb torque wrench, good set of hex, torx and socket set. Replacement o-rings for the drain plugs (p/n 17369-06 for the gasket service kit.. 1k, 5k, 10k).
I also use an automotive oil filter wrench (after I drop the voltage regulator off the downtubes... makes getting to the filter and cleaning up afterwards much easier. Use a 1liter bottle cut in half at an angle, to catch the oil from your filter... and your filter as well.
2.5qts in your engine (w/filter change), 1qt in your tranny and 1qt in your primary. Same oil in all three holes not a good idea.... my opinion. Synthetic 20/50 in the engine, synthetic 75/140 in the tranny, good dino 20/50 in the primary... again, my opinion on using friction modifiers (synthetic oil) on the clutch, not a good idea.
