06 dyna setup
Old Aug 2, 2006 | 01:49 PM
suntz's Avatar
suntz
Default 06 dyna setup
I have an 06 dyna lowrider. I want to install v&H straightshot slip ons, with the K&N filter setup and use the power commander III from fuelmoto with their downloaded map installed for this set up, any comments. Should this run fine with their map for this set up?
Old Aug 2, 2006 | 02:15 PM
thebestofindica's Avatar
thebestofindica
Default RE: 06 dyna setup
Yeah, that would work fine, just find a map that gets you close and then have it dyno tuned to pull the last few hp and torque out of it. Talking about engine management for these closed loop bikes is an endless cycle. Everyone recommends what they have and they think all others suck. That's the way it goes. If you have your mind set on the PCIII, buy it and it will be fine and you will like it. Good luck and enjoy.
Old Aug 2, 2006 | 03:59 PM
suntz's Avatar
suntz
thanks for the feedback. The setup I am speaking about seems to be good for the price of the items and the preloaded map. Most on this forum either use the power commander or the sert. I guess they are about equal.
baldie
Apr 8, 2013 10:16 PM
hddave2
Feb 10, 2013 08:41 PM
hddave2
Feb 18, 2009 08:28 AM
darkdyna06
Jun 7, 2007 10:59 PM
Shrug
Sep 4, 2006 10:45 PM
