pc3usb map 06 dyna
Old Feb 17, 2009 | 05:46 PM
hddave2's Avatar
hddave2
Default pc3usb map 06 dyna
could some one take a look at this map and tell me if there is any changes that could be made to make this map a better map for my setup...this was the map sent to me by dynojet for my setup. i tryed this map and it made the bike idle alot faster and seems that it loses power rather than make power...i have a 06 dyna superglide with se breather kit, python staggerd duels (bigshot) with the power chamber design,andrews 26h cams and a stock ecm. if someone could redo this map and send it back to me , i would be very thankfull..i wish i could get the bike dynoed but there are no places in my area that fools with the pc3usb..thanks for any and all help and advice
File Type: zip
M811-hddave1.zip (721 Bytes, 22 views)
Old Feb 17, 2009 | 05:52 PM
JayStronghawk's Avatar
JayStronghawk
Might want to try contacting Jamie at Fuel Moto...
Old Feb 18, 2009 | 05:17 AM
hddave2's Avatar
hddave2
i've called several times and they have just about gave up on me..they say they dont have a bike with my setup so they just guess on the maps...im thinking of just ditching the pc3 and going with a stage 1 download...its funny ,my step mom has a 98 883 sporty and it will run circles around my dyna. the map i posted is getting about 28 to 30 mpg and doesnt make power at all but on the good side it doent pop on decel at all so i guess its helping in that aspect. i dont know enough about the maps to know what areas to change to get the bike to run better.if some of you guys understand the maps and could maybe change some thing around so i could try it..best i can understand about the map is that its way to rich.
Old Feb 18, 2009 | 07:58 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
With your build you need the bike dyno tuned. I don't think the HD stage 1 download will help you. Find a tuner who has experience with the PCIII. If you can't find one then you might consider a SERT or Mastertune TTS system (you can tune it yourself with the mastertune setup) Contact Steve Cole first to see if the mastertune setup will work on your 06. Did you try Latus HD and see if they had a map that would work on your bike? Email Mike Stegman there. I got one from them and it runs great but I have a SERT.
Old Feb 18, 2009 | 08:28 AM
hddave2's Avatar
hddave2
i just e-mail them so i guess we will see what they have to say....thanks for the contact.
SnoRider
Aug 22, 2016 10:55 AM
KumaRide
Mar 9, 2013 08:32 AM
hddave2
Apr 26, 2009 11:44 AM
waterman7474
Feb 13, 2008 08:24 PM
MaineHD
Apr 7, 2006 08:10 AM
