Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
anyone have a pc3usb map they would care to share with me..i have a 06 dyna, stock ecm, v&h bigshots, se stage 1 breather kit , andrews 26h cams..there are no tuners in my area...please send to david_teater@att.net ,,thanks guys for any help
I was going to say download one from the DJ website, however I looked first and see that since the release of the PC-5 they have abandoned the map database they used to maintain for the PC-3.
Note any map used is a starting point and will need to be tweaked to fit your bike.
I updated my map stash to include those maps and I don't see any 811 maps that are for a bike with the stage one flash so you will have to make your own map or have a tuning center dyno your bike. I also noticed that all of the maps used O2 sensor eliminators. For best results you might want to use a PC-5 or use one of the direct access packages Mastertune, SERT, or Direct Link.
