Sert map question
Old Apr 6, 2006 | 09:57 AM
MaineHD's Avatar
MaineHD
Default Sert map question
Hello all, Big time SERT and EFI newbie here;
I have a question concerning a map i found recently. Its from the boys at Thunderheader and it can be found on their website. It says that the map is for 1450cc, their thunderheader pipe, with a SE AC. The questions i have are:
1- Is there a way to tell if this map is good to use on an 06 Dyna, because they make the thunderheader for a bunch of different models?
2- I actually bought the new Rinehart 2 into 1 pipe fro my bike. I know that the TH has unique characteristics but being that both pipes are 2 into 1's id imagine that the map would get me pretty close and i wouldnt have to worry about hurting anything on the bike?
3- Should i just use the canned map from the sert disc to be safe for now and not risk some unknown map?
4-My final option is to buy the map from HDmaps.com for the TH, 1450cc, and SE ac, as they havent completed the map for the 06 Dyna with the Rinehart pipe yet. I know this would work for the 06 Dyna.
5 The bike will be getting a Arlen Ness Stage II billet sucker intake this month once they're produced. I assume since ill be using the stock intake for now that i would really be safe
The bike will be getting a dyno tune late this month once my intake arrives from Arlen Ness, so i just want it to run good but not great, and most importantly for now Safe.
Thanks for any help you offer
Old Apr 6, 2006 | 04:26 PM
JamieWG's Avatar
JamieWG
Default RE: Sert map question
First of all, your bike has O2 sensors. Unless the TH map is specifically made for closed loop bikes, it won't work on your Dyna. Second, some Dynas have the 8 degree injectors and some have the 25 degree injectors. There are different maps for each type of injector. Third, the map from Hdmaps.com for '06 Dynas is junk. The bike pops on decel like crazy and there are descrepencies in the VE tables and timing tables that don't make any sense. Whoever put it together did a sloppy job. If I were you, I'd load up the proper canned map off the SERT disc and run it until you can get a dyno tune.
Old Apr 7, 2006 | 08:10 AM
catsass's Avatar
catsass
1st Gear
The TH map is for their #1031 pipe only with 02"s
hddave2
Apr 26, 2009 11:44 AM
hddave2
Feb 18, 2009 08:28 AM
waterman7474
Feb 13, 2008 08:24 PM
hAkron
Sep 1, 2007 05:22 AM
eunrein
Jun 29, 2006 10:19 AM
