SERT Map Question
Old Jun 26, 2006 | 01:36 PM
eunrein's Avatar
eunrein
Default SERT Map Question
2006 Deluxe (FLSTNI)
25 Degree Injectors (confirmed)
SE A/C
Big Shots Staggered (V&H 17907)
w/ Quiet Baffle (V&H 21869)
Finally have all the parts, just received the new SERT (32107-01E), I am really not interested in having bike Dyno tuned at this point, can someone recommend a good safe MAP to load and run with for this set-up?
Old Jun 27, 2006 | 12:49 AM
rrhemi's Avatar
rrhemi
Default RE: SERT Map Question
My bike has the exact SE parts on the #59 Map on the CD. I have been running it for a few weeks.
It runs better, plugs look about the same. I just loaded a tweaked map but it's been raining here in
MD so I do not know if I have improved things.
I would load the map that has the closest description to what you have. If your pipes have a little more
restriction with the quiet baffles over SE II's I would bet you would be real close. I compared the 1550
map to the 1450. I thought it might be a little richer but it wasn't any different in the A/F table. The V/E
table was different.
Old Jun 27, 2006 | 03:30 AM
WS6 Formula's Avatar
WS6 Formula
I tried several maps below, the best one so far with my setup is #32 141NX002, it seems to run better with the 8* map even though I have 25* injectors. You may want to try the map that is recommended for your bike in the Race Tuner cals with the 25* injectors, then try the 8* map and see which one runs better. I just installed this map tonight and will try it out for a couple of days and compare it to another map I have been using that was emailed to me by a member (JamieWG) of this forum that preformed pretty well. You may want to contact him and try his maps.
#59 141NX104...1450cc 25* map Race Tuner cal Recommend
#60 141NY103...1550cc 25* map
#55 141NR004...1450cc 25* map with touring mufflers
#33 141NY002...1550cc 8* map
#32 141NX001...1450cc 8* map D&D recommended
#32 141NX002...1450cc 8* map
My Bike
2006 Dyna Low Rider
engine stock internally
25* injectors
Arlen Ness Big Sucker I
D&D Fat Cat 2 into 1
SERT #32 141NX002
Old Jun 27, 2006 | 10:02 AM
fl_799's Avatar
fl_799
It's going to be difficult loading up a closed loop map from an 06 DYna on a open loop Delphi ECM.
A safe map would be a 1550 stage one map for your Deluxe. The pipes will certainly use up the extra VE table values of the 1550 map.
ORIGINAL: WS6 Formula
My Bike
2006 Dyna Low Rider
25* injectors
SERT #32 141NX002
Old Jun 27, 2006 | 09:04 PM
WS6 Formula
fl_799,
I agree, I added the word "version" ,...................hope that is a little more understandable.[sm=yikesomg.gif]
ORIGINAL: fl_799
I tried several maps below, the best one so far with my setup is #32 141NX002, it seems to run better with the 8* map even though I have 25* injectors. You may want to try the map that is recommended for your bike in the Race Tuner cals with the 25* injectors, then try the 8* version map and see which one runs better. I just installed this map tonight and will try it out for a couple of days and compare it to another map I have been using that was emailed to me by a member (JamieWG) of this forum that preformed pretty well. You may want to contact him and try his maps.
My Bike
2006 Dyna Low Rider
25* injectors
SERT #32 141NX002
Old Jun 29, 2006 | 10:19 AM
eunrein's Avatar
eunrein
Thanks everyone, especially Shovelhead Bob, map 53 CAL ID 141NQ003 for the 2006 Shotgun / Shorty Dual Style Exhaust appears to be about dead on. Will do some more testing over the long weekend.
flyingdutchman
The Dyno Room
Sep 13, 2016 01:08 PM
SnoRider
Aug 22, 2016 03:21 PM
mvent
Dec 28, 2007 03:05 PM
mvent
Dec 4, 2007 11:26 AM
hAkron
Sep 1, 2007 05:22 AM
