Lowered rear, re-aim light?
Old Mar 24, 2010 | 08:18 PM
JT-FXDL's Avatar
JT-FXDL
Question Lowered rear, re-aim light?
The rear is lowered about 1.5". I road the other night but couldn't see too well, and my high beam seemed waaaay out there. I will check the headlight based on the manual, but is it normal to have to do this?
Old Mar 24, 2010 | 08:37 PM
korgie's Avatar
korgie
Stage I
all you have to do is manually adjust the light, there are specific measurements that it should be set to. if you park 25 ft away from a wall and shine your headlight at it, the center of the light should be roughly 3 ft high.( i had the same problem with my 04 low)
Old Mar 24, 2010 | 08:38 PM
HDDyna2006's Avatar
HDDyna2006
loose screw and readjust headlight, lowered rear front points up, simple science.
Old Mar 24, 2010 | 08:41 PM
JT-FXDL's Avatar
JT-FXDL
So what you're saying is I have a loose screw and need my head adjusted becasue I don't understand simple science?
Old Mar 24, 2010 | 08:45 PM
lilspanky's Avatar
lilspanky
What did you do to the rear to lower it
Old Mar 24, 2010 | 09:02 PM
JT-FXDL's Avatar
JT-FXDL
lower shocks (Progressive 412's)
Old Mar 24, 2010 | 09:23 PM
Taddeoeg's Avatar
Taddeoeg
So what if you don't have 25 feet of level surface to check the adjustment? Is there a way to do this in a shorter distance? My driveway runs uphill to the garage, so that won't work, and a garage is only about 21' deep, so if I park the bike right at the door I'm only 15' or so from the wall.
Any tricks or tips for adjusting headlights?
Thanks
Old Mar 24, 2010 | 09:32 PM
Lorance66's Avatar
Lorance66
I did when I lowered mine. Mine was high also after the lower shocks.
Old Mar 24, 2010 | 09:56 PM
08fxdf43202's Avatar
08fxdf43202
Thanks
Is that a trick question?
Wait till dark, lossen the bolt... just a little and put the wrenches in your pocket.
Go for a ride, find a steady level length of road, reach over the bars & 'tap' the headlight till you like it.
Pull over and tighten the bolt.
Old Mar 24, 2010 | 10:54 PM
archergodwin's Avatar
archergodwin
X1.....
