Set shocks
Old Aug 3, 2006 | 11:21 PM
Asuperglide's Avatar
Asuperglide
Default Set shocks
I want to change the shocks setting and not sure there both in the same position right now. Standing rear facing the rear fender do I CW the left and CCW right all the way and where is the firm setting, all the way CW (right) or opposite? I don't know if there any difference between the R & L shock or are they the same? TIA
Old Aug 4, 2006 | 01:09 AM
mud's Avatar
mud
Default RE: Set shocks
ORIGINAL: Asuperglide
When you turn, and the spring compresses, that is the more firm setting.
CW CCW,don't remember.
R & L are the same.
mud
Old Aug 4, 2006 | 01:16 AM
ss377's Avatar
ss377
You can do what I did. Get a mirror and flashlight and look under the skirt of the shock and check the position. More compression is a firmer recoil setting. I think you turn both the same direction. Just turn them equally. That's where the mirror comes in handy.
Old Aug 4, 2006 | 01:38 AM
TRITON's Avatar
TRITON
Just bottom them out then go from there. If you don't have the adjustment tool, I would highly recomend it. It's about $12.00, but will save your knuckles.
Old Aug 4, 2006 | 10:45 AM
MARCUSBEAR's Avatar
MARCUSBEAR
I know on my wide glide there is six settings ( five clicks) on the rear shocks , clockwise makes the shocks firmer , counterclockwise softer , adjust both shocks at the same time , do one or two clicks at a time on each shock to keep track of your adjustment , I weight 280# so I have the shocks at max firmness
Old Aug 4, 2006 | 05:37 PM
bobcowan's Avatar
bobcowan
Both shocks are the same. L and R are interchangable. Turn them both the same direction.
Old Aug 4, 2006 | 11:08 PM
Asuperglide
Thanks All..............
Old Aug 6, 2006 | 05:05 AM
jimw411's Avatar
jimw411
I weigh 280 and have my shocks set on 2 and even 180 chick riding on the back it's fine.
Old Aug 6, 2006 | 01:26 PM
jackyl's Avatar
jackyl
just look under the skirt on the shocks.look at the lower skirt, threw the holes and thier are numbers on them.check if both match and raise the number or lower.for your riding comfort.make sure they are both the same.if you dont have them the same number ,you will get a wobble in the **** end.very easy to check.
albngore
Jan 14, 2019 07:47 AM
big- mike
Jan 29, 2018 03:45 PM
SinCalBear
Sep 18, 2014 10:01 PM
greg3131
Aug 16, 2008 08:10 PM
rambo1313
Jul 16, 2007 09:04 AM
