HELP: Removal of Brake Pedal for 09 FXDB?
Old Mar 27, 2010 | 05:30 PM
BrentsterS's Avatar
BrentsterS
Default HELP: Removal of Brake Pedal for 09 FXDB?
2009 FXDB:
Have the mid mounts off and removed the cotter pin but don't see how to remove the brake pedal from the linkage or the mid mounts.
Any help?
Old Mar 27, 2010 | 05:52 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
I remember I had to tap it out from the inside with a hammer and a flat screw-driver when I mounted floorboards on my FXD2003 a few years ago.
FXD2003Rider
Old Mar 27, 2010 | 05:53 PM
bberck's Avatar
bberck
Once you remove the coter pin there is a pin that slides out to remove the linkage. You make have to remove the midmount for it to rotate enough to slide out freely dont recall off hand.
To get the brack pedal off there is just a c-clip on the inside of it. Pop it off and it will slide right off.
Old Mar 27, 2010 | 07:49 PM
mud's Avatar
mud
Originally Posted by BrentsterS
2009 FXDB:
Any help?
if I understand your question...
should be able to get it with this........................
clevis
Old Mar 29, 2010 | 11:14 AM
macnab_sf's Avatar
macnab_sf
Mud - this pic just made a huge difference for me. I was stuck right here on my Thundermax install (routing the oxygen sensor cable wires to front cylinder along inside of frame rail). I had given up on getting the brake pushrod disconnected from my forward brake pedal, and zip-tied the O2 cable connection [1] under the outside of the frame where it was hanging at risk to road hazards.
Your pic shows such a simple idea that it borders on obvious once you see it, yet I did not think of it myself in the moment. I was hammer-banging and decided it wasn't going to work. I assumed the pin was frozen in there and was gonna leave it until I could consult a pro wrench.
Thanks for continuing to take pics and post things which appear simple once you see them, but for some reason fail to be apparent to green wrenches. This makes a big diff in showing how to be creative as a wrench and thinking outside the box.
Dan
[1]huge connector plug would not get in past the rod.
Old Mar 29, 2010 | 09:03 PM
mud's Avatar
mud
Dan
Nice to hear that this helped you out Dan.
label on the pix say they were taken in Jan of 2007.
Simple. Yes.
Like Terry Allen says - sometimes you go North to get South
hopski
Sep 28, 2017 10:47 AM
MeanieNJ
Powdercoat & Paint
Jul 7, 2014 11:26 AM
Chicago Ken
Feb 5, 2014 06:58 AM
Kolni
Jul 5, 2007 05:42 PM
dlkeneipp
Dec 10, 2005 12:39 AM
