Install of extended brake pedal
Old Dec 9, 2005 | 10:18 AM
dlkeneipp's Avatar
dlkeneipp
Default Install of extended brake pedal
Just received new extended brake pedal and am ready to install. Wanted to know if any thing that I should do or be aware of during the install. Thanks David
Old Dec 10, 2005 | 12:39 AM
wvrider's Avatar
wvrider
Default RE: Install of extended brake pedal
I'm not sure about other bikes; but on a RK. 1 remove the cotter in from the clevis pin that holds the pedal to the master cylinder (can be a bit tricky to get to). 2 remove the clevis pin (may have to use a screw driver and hammer to knock it loose). 3 remove the nut that holds the brake pedal to the shaft and remove the pedal.
Cruisineasy
Jul 2, 2019 12:14 PM
brandss
2014-2024 Touring Models
Jun 1, 2017 03:16 PM
58sniper
Apr 5, 2015 06:28 PM
wormtail
Mar 14, 2014 11:39 AM
twohats
Jul 14, 2006 09:47 AM
