map ?
Old Apr 7, 2010 | 10:19 PM
wickeds10's Avatar
wickeds10
Default map ?
im installing a set of andrews 37h's and 10.5:1 pistons tomorrow in my 88"doing a mild port job also i have a se af kit samsons bg3 sweepers and pc3 what map should i dl for the commander the guy from dynojet said i cant use the touring maps cause i have a dyna is this true?
Old Apr 7, 2010 | 10:46 PM
redrubicon2004's Avatar
redrubicon2004
I would have someone dyno tune it once done.
Old Apr 8, 2010 | 01:21 AM
paul s's Avatar
paul s
A canned map is alright for pipes and AC but with cams and porting a full tune is best. I sure like my T-Max w/AT.
Old Apr 8, 2010 | 02:52 PM
wickeds10's Avatar
wickeds10
i plan on doing a dyno tune i just need to be able to make sure its good for a out the door deal so i can get it home.
Old Apr 8, 2010 | 11:08 PM
archergodwin's Avatar
archergodwin
If you already have the PCIII, contact Jamie at Fuelmoto, he's on the forum here. He can probably get you a map pretty close, till you can get it dyno'd.
Naruto666
Jul 2, 2018 11:49 AM
cmcsns
Jul 16, 2010 10:29 PM
JR-Boston
Apr 26, 2010 04:16 PM
David Alves
May 4, 2007 01:55 AM
*Road King*
Jan 18, 2007 09:01 PM
