rotor
Old Apr 13, 2010 | 08:50 AM
merc68's Avatar
merc68
4th Gear
Default rotor
does anyone know the torque for the screws that hold the rear rotor to the wheel? Also what is the torque of the rear axle nuts?
thanks
Old Apr 13, 2010 | 10:05 AM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Posting the model and year of your bike will help to find the correct settings...
FXD2003Rider
Old Apr 13, 2010 | 11:18 AM
grbrown's Avatar
grbrown
Thumbs up
thanks
If you are pulling your bike apart, get yourself a factory service manual. It has all that stuff and much more.
Old Apr 13, 2010 | 02:25 PM
QehQeh's Avatar
QehQeh
VERY IMPORTANT: I'm ***-u-ming you don't have a service manual - If you're planning on reusing the old bolts, make sure this is OK for your model bike. Some of these type of bolts are meant to be torqued only once. If you reuse them they could fail under load - not a good thing!
Old Apr 13, 2010 | 10:47 PM
merc68's Avatar
merc68
4th Gear
thanks for all the advice..
1. It's a Dyna---that's why I posted it in the DYNA SECTION.
2. if I had a manual I wouldn't have to ask..would I?
I thought the forum was to help each otherf , not to say go get a manual and find out yourself.
Old Apr 14, 2010 | 01:03 AM
EricInNCa's Avatar
EricInNCa
Dude, with that kind of attitude you might not get much help. Everyones got a busy life and it takes time to find information to help each other out. It's only out of the goodness of their heart that you'll get help. It's not a requirement.
Old Apr 14, 2010 | 04:22 AM
grbrown's Avatar
grbrown
Cool
merc68,
You haven't been around HDF very long. What you are asking one of us to do is get out our service manual, which we paid for with our own money, look through it and find the information you want, for free. If you are going to start working on your own bike, you will find your own manual very helpful in many ways, as well as supplying that information. This forum works best when you hit problems not covered in the manual, when we can use our experience to help you. But you have to start by helping yourself!
If you are lucky, you may have rotor bolts that have a service life of 3 applications, otherwise you need to buy a fresh set. That means you can tighten them up to full torque just three times before replacing them. How do I know? because I just fitted a new rotor to one of my other bikes. If you are fitting a new one the instructions came with it, including torque figures.
We still don't know what model and year your bike is. For a 2003 Dyna the torque is 30-45 ft lbs, using blue Loctite as well.
While you are at your local dealer getting new screws, to be safe, also buy yourself a manual! And parts list.
Old Apr 14, 2010 | 02:29 PM
FXD2003Rider
grbrown and EricInNCa: I'm with you!!
merc68,
Although I still don't know the specific (Dyna) model and year of your bike, "I will turn the other cheek" by posting the info below after having done a job in the Dyna models section for "critical fasteners" and "torque values". I hope this will suit you, sir!
Credits to the members who initially posted the info below!
FXD2003Rider
Originally Posted by Z
Here's the list of critical fasteners for an 06 Dyna (Thanks RJSOGARD!):
http://www.bafpg.com/downloads/06_dyna_cf.pdf
When GREENOHAWK69 is able to compile his list, I'll post that here too. (Thanks in advance for that, GREENO!)
Originally Posted by jmpancoast
Here is a chart showing critical fasteners as listed in the 06 manual.
Just because a fastener isn't listed above doesn't mean it isn't critical.
Originally Posted by BigLowRider
I created a list of torque values for the 2003 Dyna models as shown throughout the HD Service Manual. I got tired of looking through my manual so I combined them all into one double-sided document. It also includes the critical fasteners.
This document is for quick reference only, please consult your own service manual for verification. Torque Values are for 2003 Dyna models only. Remember to always disconnect your battery before servicing your motorcycle.
The attached file is in pdf format. It can be opened, saved, and printed with the Adobe Acrobat Reader, which comes free with most computers.
BigLow
MyFavRk
Feb 10, 2019 06:49 AM
AdrianVall
Oct 14, 2018 01:44 AM
ExDucRider
Oct 14, 2013 03:22 PM
MrCookie
Jun 12, 2011 02:09 PM
disom007
Apr 2, 2007 03:33 AM
