2007 LR Drip From Shifter Peg
Old Apr 18, 2010 | 02:03 PM
Dynamite17's Avatar
Dynamite17
Default 2007 LR Drip From Shifter Peg
I notices a few spots of oil on the groundunder the shifter peg on my 2007 Low Rider. The bushing on the peg is slightly wet. Took off the derby cover and put in a few ounces to top off. Using Mobil 1 20w50 in there.
Is there a seal that is easily replaced if I took off the chaincase cover?
Bob
Old Apr 18, 2010 | 05:08 PM
SuperFastGlide's Avatar
SuperFastGlide
theres a little round gasket between the outer cover and inner primary cover where the shifter shaft runs thru called a tower gasket.. common problem but an easy fix.. just have to pull the outer cover and replace the gasket..
Old Apr 18, 2010 | 07:27 PM
Dynamite17's Avatar
Dynamite17
Thanks, looking at the service manual on p6-2 it says I need to loosen the rear axle nut before removing the chaincase cover. I don't understand why that is necessary if I am going to replace that tower gasket. Besides the cover gasket which I assume I'd replace on this job, anything else that will come off?
Bob
Old Apr 18, 2010 | 09:06 PM
SuperFastGlide
no need to loosen axle nut.. i re-used my outer cover gasket
Carlos Frijoles
Shovelhead
Jan 13, 2017 08:33 PM
Yankee Dog
EVO
Aug 18, 2013 09:33 PM
98glider
EVO
Sep 3, 2010 08:56 PM
dFREDb
Aug 26, 2010 08:36 AM
dotcom2000
May 7, 2009 06:06 PM
