Map request
Old Apr 23, 2010 | 02:20 PM
Kaycee's Avatar
Kaycee
I hear ya about the budget,I have been contemplating this move myself, just the cams.Let us know how u like it and imorovements
Old Apr 23, 2010 | 02:22 PM
8541hog's Avatar
8541hog
Hell yea... What do you need a cameraman for? Probably should have asked BEFORE I agreed...LOL
Old Apr 23, 2010 | 02:44 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by SC-Longhair
Rene, I guess that answered my question. From that link the spacers fit between cam timing gear and cam plate, I'd assume for chain alignment purposes.
Vic,
Checked my 2003 Service Manual. Here's what it shows on the rear cam sprocket spacer:
Quote:
"Height differences between rear cam sprocket and crank sprocket can be addressed by changing the spacer behind the rear cam sprocket"
Old Apr 23, 2010 | 02:47 PM
SC-Longhair's Avatar
SC-Longhair
Well, it doesn't involve a country gal and a horse, I can tell you that much.
I want to do a cam install video.
Old Apr 23, 2010 | 03:06 PM
8541hog's Avatar
8541hog
Whew...
When do you want to do it? Sounds like a good excuse for a ride.
Old Apr 23, 2010 | 03:31 PM
paul s's Avatar
paul s
If you're pulling the rockers to reuse the push rods that head gasket isn't too far away, a .030 will give you about .25:1 more compression. I know it isn't much but every little bit helps.
Old Apr 23, 2010 | 03:37 PM
thedonthere's Avatar
thedonthere
Vic,there are about 5 different cam spacers that come in .010" increments. I suggest to buy all 5, measure, use the appropriate spacer and return the ones you don't use. That might save you an xtra trip to the dealer. The dealers I have dealt with will let people do this. Also, make sure you get the timing dead on.1 tooth off f#@#s **** up. Also if your just doing cams, a 4* advance cam gear will really wake it up.
Old Apr 23, 2010 | 03:45 PM
FXD2003Rider
Originally Posted by thedonthere
..Vic,there are about 5 different cam spacers that come in .010" increments.. .
Here are the p/n's:
25722-00 ==> 0.287 inch 7.29 mm
25723-00 ==> 0.297 inch 7.54 mm
25721-00 ==> 0.307 inch 7.80 mm
25719-00 ==> 0.317 inch 8.05 mm
25717-00 ==> 0.327 inch 8.31 mm
Old Apr 23, 2010 | 04:04 PM
thedonthere
Originally Posted by FXD2003Rider
Here are the p/n's:
Rene here are the PNs I have:
25729-06>>0.100"
25731-06>>0.110"
25734-06>>0.120"
25736-06>>0.130"
25737-06>>0.140"
25738-06>>0.150"
I'm fairly sure that the 25729-06 is the stock spacer,at least it was on my bike. The numbers you list are for the pre 2006 dynas which is different
Old Apr 23, 2010 | 04:09 PM
FXD2003Rider
..The numbers you list are for the pre 2006 dynas which is different..
Right you are, Don...they come from my 2003 Dyna Models Service manual!
