Nitrous oxide on high compression motor
Old May 3, 2010 | 02:13 PM
thelawcc8's Avatar
thelawcc8
Stage I
Default Nitrous oxide on high compression motor
Hello, I looking for imformation about running nitrous oxide on a high compression motor. I have a 2005 dyna wide glide built to a 95ci. the top end is max out. Dave Makcie heads ported/polished, SE HC 1550 Piston Kit, SE 260 CAM, quick install pushrod kit, SE heavy breather, compression realease kit. The bike makes 100HP/100TQ. I was thinking about putting a .30 to .40 shot on the bike. I haven't been able to get much feed back on this. Thanks for your advice. Chris
Old May 3, 2010 | 02:22 PM
paul s's Avatar
paul s
https://www.hdforums.com/forum/blowe...ous-oxide-143/ Try here. It can be done, make sure you have forged pistons.
Old May 3, 2010 | 04:40 PM
bikerlaw's Avatar
bikerlaw
Wether your motor can take the hit or not, I have no idea. But any racer at any track can tell you....nitrous loves compression. Timing does not.
Kuzmitch Davidson
Engine Mechanical Topics
Apr 9, 2018 09:23 AM
otto76689
Aug 26, 2016 02:56 PM
sharkey
Sep 28, 2015 11:13 AM
twism_23
Exhaust System Topics
Nov 16, 2012 03:07 PM
drhooligan
Nov 24, 2007 08:55 PM
