When to Re-Torque
Old May 5, 2010 | 10:24 PM
cosper's Avatar
cosper
thanks
Old May 5, 2010 | 11:44 PM
editbrain's Avatar
editbrain
This has got me curious. I looked on page C-3 of the 2010 Dyna Service Manual for the conversions of inch lbs to ft lbs, and it came out to around 9.9 ft lbs of torque (10 lbs). I got the torque wrench out. I had a bolt on each that needed a good bit of tightening to bring them to spec.
I have doubts about the gaskets on my bike being that the first pipe was bad, then the stocks put back on, and then they put the T-headers on.
Like the other more experienced HD riders here have said. They will loosen up on ya, but I bet the finally get settled. I bet I have do to the same as you soon, and change out my gaskets. I get some popping now and then.
Old May 6, 2010 | 10:23 PM
coop creek's Avatar
coop creek
which gaskets did you use, the stock ones or the flat ones (screamin eagle)? Were you able to replace the gaskets without disconnecting the O2 sensors?
Old May 7, 2010 | 06:48 AM
nathanw's Avatar
nathanw
I have lost a flange nut in the past, so I check it for the first few rides now.
Old May 7, 2010 | 09:40 AM
Grendel4's Avatar
Grendel4
There are 12 inch lbs in a foot lb. Seems obvious, but -- Oh well.
Anything under fifteen-twenty foot pounds and I don't trust my foot lb wrench. I have three -- A 1/2" drive foot lb, a 3/8" foot pound and 1/4" drive inch pound. Yeah, they're cheap suckers. Cheap, cheap. But so what? You can buy a $400 Snap On and use it twice a year and it'll go to hell on you from just sitting. Or you can do like me and buy the dirt cheap ones form Harbor Freight and realize that they're not totally accurate but still better than taking a wild guess.
Then throw it away if you don't trust it anymore.
Old May 7, 2010 | 10:06 AM
editbrain's Avatar
editbrain
Your math is not correct in figuring the inch lbs to foot lbs conversion.
The equation is (inch lbs value (0.08333) = ft. lbs).
So 100 inch lbs would be 8.33 ft. lbs, and not 12 ft. lbs.
I mean you could be as much as 4 ft lbs off if not done correctly. That could multiply quickly if a large amount of torque was called for, and you could end up breaking something. It just all depends on how precise you want to be.
Here is an online reference http://www.convertunits.com/from/inch+lbs/to/foot+lbs
Old May 7, 2010 | 10:19 AM
8541hog's Avatar
8541hog
Dividing by 12 gives you the same answer. 100/12=8.33
Old May 7, 2010 | 10:55 AM
editbrain's Avatar
editbrain
Yes.
I guess it all cancels out. I have an excuse for being a dumb *** right now. I have a 9 month pregnant woman who will not let me sleep..
Old May 7, 2010 | 12:47 PM
BIGDADI's Avatar
BIGDADI
I used stock replacement, heard some bad things about the screaming eagles and the stock replacement is cheaper. I did not have to remove the O2 sensors however the I did have to wrap the pipes in a towel to keep from scratching them since they were dangling by the O2 sensor wires. I was careful took my time and it still took less then 1hr start to finish.
I did the math my self as far as the divide by 12 conversion, my book called for 9-18inch pounds on the bottom nut then 100-120inch pounds on the top nut, then back down to the bottom nut to 100-120inch pounds. So I set the torque wrench to 10Ftlbs and went to town. I guesstimated the 9-18inch pounds and then torqued the rest to specs. No issues. Super Easy.
paco12
Aug 17, 2019 10:41 AM
autobite
Apr 20, 2015 09:02 AM
joechiu1024
Nov 4, 2011 06:21 AM
fonemann
Exhaust System Topics
Mar 15, 2008 02:01 AM
jserigne
Ironhead
Jan 22, 2008 08:26 PM
