When to Re-Torque
Old May 5, 2010 | 05:09 PM
BIGDADI's Avatar
BIGDADI
Question When to Re-Torque
Just changed my Exhaust Gaskets today on the bob. Almost made a fatal mistake when torquing the flange bolts, the book was in Inch Pounds and my Torque Wrench is Foot Pounds. Glad I caught that on the first bolt, before snapping one. Anyway Bike runs way better now no more "snap crackle pop" Thank God.
So my question, how many miles till I need to re-torque the flange bolts?
Old May 5, 2010 | 06:05 PM
8541hog's Avatar
8541hog
As a general rule I check all the basic bolts when I do my regular maintenance and oil changes. So every 5000 miles.
Old May 5, 2010 | 06:40 PM
BIGDADI's Avatar
BIGDADI
Yeah, but I thought with new gaskets, it would need to be done sooner specially since the gaskets are made to crush. IDK could be wrong
Old May 5, 2010 | 06:52 PM
8541hog's Avatar
8541hog
After a new install check them after your first ride, once it has cooled, then regular maintenance.
Old May 5, 2010 | 07:44 PM
Taddeoeg's Avatar
Taddeoeg
Yup. Go through a heat/cool cycle then check the torque. If you're an ****-retentive like me, you might do that the first 2-3 times you ride. After that, if they haven't moved they aren't going to. The key isn't miles, it's the heat/cool (expansion/contraction) cycles that matter.
And kudos for being conscientious enough to think about this.
Old May 5, 2010 | 07:56 PM
Nevar's Avatar
Nevar
go for a good ride or two, let her heat up, then when home cold, give the nuts a twist just for the hell of it. You will be suprised.
Old May 5, 2010 | 09:22 PM
BIGDADI's Avatar
BIGDADI
Sounds good to me. Thanks guys, and I am kinda OCD so I will prob check for the next 4 or 5 days of riding. Just make sure
Old May 5, 2010 | 09:25 PM
bberck's Avatar
bberck
I retorqued mine after the first few rides but once was probally enough. I dont recall them moving when i checked them the 2nd time.
Old May 5, 2010 | 10:02 PM
cosper's Avatar
cosper
looking for some education,,,why would you change your exhaust gaskets?
Old May 5, 2010 | 10:14 PM
BIGDADI's Avatar
BIGDADI
When I installed the Big Rad. I did not change the gaskets. I was experiencing popping on decel, even though I have a fuel pak. I knew I was not running lean, since I had the bike dyno'd and sent the results to vance and hines to have a custom map made for my bike, so the next likely culprit is a exhaust or intake leak. Being I knew that I did not change the exhaust gaskets when I changed pipes I choose to try that first. To my pleasure I was right and the problem is fixed.
