Install help for big radius??
Old May 9, 2010 | 02:17 PM
Desertdog7's Avatar
Desertdog7
Default Install help for big radius??
Hey fellow riders. Just got some V&H Big Radius exhaust for my 01 FXDL. I'm planning on doin the install myself. Does anybody have any tips or how to or what not to do's with the install. V&H said its pretty straight forward. Any help would be great.
Thanks,
DD
Old May 9, 2010 | 02:25 PM
ghostrider69's Avatar
ghostrider69
It's pretty straight forward.
Old May 9, 2010 | 02:28 PM
Desertdog7's Avatar
Desertdog7
Cool!! thanks for your time.
Old May 9, 2010 | 04:34 PM
rounder's Avatar
rounder
very easy to install. IMHO ignore the instructions and install and tighten the heat shield before the exhaust is put on the bike. I used to have the 2-2 big radius. Had them off and on the bike a couple of times. The heat shields will not interfere with the installation of the exhaust on the bike. I remember following the instruction and tightening the heat shields with the exhaust installed was a pain in the butt!.
Old May 9, 2010 | 04:46 PM
Desertdog7's Avatar
Desertdog7
ok cool. Great info. thanks. sounds like a time saver.
Old May 9, 2010 | 05:21 PM
ghostrider69
Make sure you install new exhaust gaskets. Get the pipes started up on the heads loosely then loosely to the mounting bracket. Tighten the flange bolts on the heads first then tighten the pipes to the mounting bracket after you get them aligned properly so that they have an even gap between them.
Old May 9, 2010 | 05:25 PM
judas666's Avatar
judas666
if you do follow the instructions be sure you set up your heat-shield screws so you can actually get a screwdriver to them to tighten them down once the pipes are on the bike. or just tighten before you put the pipes on. also be sure to wipe all your oily fingerprints off the pipe before you fire it up. an extra set of hands help as well when your trying to get it in the actual exhaust ports, probably the toughest part of the install. this is all assuming we're talking about the big radius 2-1...
Old May 9, 2010 | 07:22 PM
Desertdog7's Avatar
Desertdog7
Guys,
Thanks so much for the info!
Old May 10, 2010 | 07:54 AM
n2thecraft's Avatar
n2thecraft
always a good idea to let the pipes cool down before ya take 'em off,,,, ,I would.
Old Jun 12, 2010 | 12:39 PM
charle's Avatar
charle
No to hijack you tread but.......
I really like these pipes and was thinking about getting a set. But do you need forward controls with them?
