Free spinning starter
Old May 10, 2010 | 12:53 PM
mucklepilly's Avatar
mucklepilly
2nd Gear
Default Free spinning starter
Hi all.
Any of you mechanical wizards out there can help with this one?
1998 Dyna FXDS. Tried to start her today but the starter motor sounds like it's spinning free but it won't engage and turn the motor. I've head the sound a few times before but she's always started on after two or three tries.
Any ideas would sure be helpful.
Thanks a heap in advance.
Mucklepilly.
Old May 10, 2010 | 01:13 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Starter clutch is bad or solenoid or both. Keep bumping it and you might get lucky but better order the new parts if you are going to DIY. If not make sure your dealer has them so you don't get stranded waiting for parts.
Old May 10, 2010 | 01:51 PM
mucklepilly
2nd Gear
Thanks KB.
Is there any point in ripping the starter out and lubing the shaft? I can hear the solanoid trying to work but it sounds like it throw the bendix out far enough. I know I've done that with cars in the past, whaddy reckon?
Mucklepilly
Old May 10, 2010 | 03:37 PM
maddghost's Avatar
maddghost
Originally Posted by mucklepilly
Thanks KB.
Mucklepilly
Once the starter is out you may as well have the drive clutch in hand 'cause no amount of lube is gonna replace that for you.
Old May 16, 2010 | 06:36 PM
cptron's Avatar
cptron
Same problem here and it was the overrunning clutch. Supposedly a very common problem but then what isn't.
Old May 17, 2010 | 06:44 AM
mucklepilly
2nd Gear
Default Job done
Thanks for all the advice. It was the over-run clutch which stopped co-operating. All done and back together now and not even the trace of a leak from the primary cover after the first 120 miles.
Cheers - mucklepilly.
FLHTChip
11
Jun 24, 2013 09:25 AM
dynamac
Nov 27, 2012 08:36 PM
andre747
Nov 9, 2011 05:11 PM
dsbducracer
May 21, 2011 11:35 PM
02glide
Oct 26, 2006 01:00 AM
