Rear Fender
Old May 17, 2010 | 01:04 AM
por2gezo's Avatar
por2gezo
Default Rear Fender
Guys,
Can someone direct to a location where I can find a how to: Remove the rear fender on my street bob .... I need to intall some new Blinkers but want to figure out how I can install them without having my reat tire rip them apart when I hit a pot hole.
Any suggestions appreciated !
Old May 17, 2010 | 05:33 AM
08fxdf43202's Avatar
08fxdf43202
The Factory Service Manual.
Old May 17, 2010 | 06:00 AM
rounder's Avatar
rounder
remove seat. Remove strut and signal bolts and fender comes off. You will need to unplug the rear signal and tail lights from the harness. On the pre 06 models there is a bolt at the front of the fender as well. I think the newer models don't have this 5th bolt. Long as you have space(finger width or so) between the tire and bolts, you will not have a problem.
Old May 17, 2010 | 06:11 AM
spaceblue's Avatar
spaceblue
One other note on the wiring. Everything unplugs inside the tail light housing. Remove the red lens, push each of the three retaining clips and unplug the harnesses. PM me if you need anything additional.
Razorback Rob
May 5, 2017 05:12 PM
dmlogs0
Apr 6, 2014 10:27 AM
THUND3RHOR5E
Mar 10, 2014 11:13 AM
wico1
Apr 3, 2008 02:31 AM
IronHead2822
Nov 27, 2007 06:53 AM
