Chubby drag bars
Old May 21, 2010 | 08:56 AM
Hickey's Avatar
Hickey
I actually thought about nightrod, and nightster bars for that matter. decided to move more towards no rise at all.
techknowguy, thanks for the pics! although its not very noticable with chrome, the odd shape of the integrated risers and that gap because of it would drive me nuts with a flat black, so maybe I'll just have to go with a 1 inch bar, or change out the top tree.
things just get more and more expensive, dammit.
Old May 21, 2010 | 09:01 AM
Desertdog7's Avatar
Desertdog7
Width: 31"; Center Width: 8.5"; Pullback: 6.0"
I like them man. you do lean forward.... but i dont ride for hundreds of miles at a time. The lowdown drag bars handel GREAT. plus having a dyna, you get the permormance that it can offer. real nimble.
Old May 21, 2010 | 09:05 AM
rounder's Avatar
rounder
I also think a 1" bar would be best. Just be sure to get one wide enough to avoid hitting the tank with your throttle/idle cables. Also look at flanders 1" bars, they have a few styles of drag bar and they come black and are drilled for internal wiring. Anything you find in drag specialties catalog...20% off at Zanotti's. From your sig. picture, it looks like you have a long torso and arms, I would recommend doing something with very little pullback so you can lean from your hip area and the bars are not in a location to just cause you to bend forward with your midback. If you lean from your hip and don't curve your spine, the comfort should be fine as long as you don't have lower back problems. I had a problem with my long arms and nighttrain bars/risers, the bars were a little too high and close to lean forward from my hips, the location had me unable to reach with the back upright so i would just extend my reach with the midback which really got painful after about an hour or two. Another thing, your gonna put more weight on the front end, so expect it to feel softer that it does now.
Old May 21, 2010 | 09:07 AM
Desertdog7's Avatar
Desertdog7
you prob already know this.... but, watch going too low with the bars. when you turn them all the way they could get into your gas tank and gas caps. dented my cap the first time i installd mine. had to rotate them up a bit. just a little fyi
Old May 21, 2010 | 09:09 AM
Desertdog7's Avatar
Desertdog7
Sorry.. didnt see rounder's post up there. im beating a dead horse.
Old May 21, 2010 | 09:20 AM
Techknowguy's Avatar
Techknowguy
I hear ya on the risers and 1" to 1.25" transition... I have already considered eliminating the risers and plan to build a custom mini tach mount that will sit between the bar clamps so you don't see the drop from 1.25" to 1.0" in that space.
The fun never ends! That's what I love about the Street Bob platform; millions of ways to go to suit everyone's needs.
Old May 21, 2010 | 09:29 AM
DesertDyna's Avatar
DesertDyna
This is probably not relevant since you want to go low and performance..but oh well. I have something similar. Drag style chubby bars with the 1" transition and grip area. If you look at my signature pic, it shows my 6" risers which are taller than what you mentioned. Looks good, but for me there were a couple of drawbacks with this height or lower risers. Depending on your height, you may find yourself riding bending slightly forward and down. Not the most comfortable on long rides, but does handle well. Another drawback, with my removable windshield, my riding position put the top of the windshield at my eye level, instead of me looking over. That was annoying. I also could not lean back much on long rides.
To help, I put on 9" "chubby" risers, and with the wideglide rake, it put my handlebar up and back into a more comfortable riding position. I can now easily see over the shield, as I sit a little more upright, and can lean back into my backrest (wife or bag) if I need to. Much more comfortable...and I have to say...the longer riser gives the front end look a little longer stretched look. And as a bonus...still handles well. Going from 6 to 9...I thought I might have some cable/wiring issues, but I found after I mocked it all up that I only needed a new clutch cable.
w/ 9" riser
closeup of bar/riser transition area
Old May 21, 2010 | 09:34 AM
Mole Rat's Avatar
Mole Rat
I am looking at these, a little expensive but they look great!
http://www.carlinidesign.com/handleb...er/lowdown.php
Old May 21, 2010 | 10:05 AM
Hickey's Avatar
Hickey
definitely going to check them out, you think 30-31 would be wide enough where I wouldn't have to worry about this issue?
They are pretty sweet, but I have the integrated risers. Although I would love to switch out the top tree, $$$.
I started with crotch rockets, so leaning forward isnt much of a concern, especially if I'm going to gain a lot on the handling end of it.
Old May 21, 2010 | 10:44 AM
rounder's Avatar
rounder
should be ok with 31-32" bars. One thing that can help is the first thing to contact the tank will be the extra throttle cable on their. You can just run one cable and this will solve that. I run one cable, plenty safe.
