problem installing tank lift
Old Aug 16, 2006 | 11:33 PM
Cory's Avatar
Cory
Default problem installing tank lift
I got a 3" tank lift for my 2006 Bob and I finally got around to putting it on tonight....I have a small problem. I got the breather line and crossover fuel line off, but when I try to lift the front of the tank, the smaller wire harness of the 2 harnesses wont allow me to lift the tank more than about 1 1/2" more than stock. I've pulled and tugged on that wire loom as hard as I care too without fear of breaking a connection and there just isnt anymore slack.
any ideas?
Thanks for your help.
Old Aug 17, 2006 | 12:00 AM
stc13's Avatar
stc13
Default RE: problem installing tank lift
take off the console ... problem will be solved
this happend to me as well and tommay suggested the same thing and it worked
Old Aug 17, 2006 | 12:42 AM
Cory's Avatar
Cory
you are correct sir! I took the console off and saw that the wire loom was wrapped around the bracket. after unwrapping the wire loom, I had plenty of slack!
I'll post pics soon.
thanks!
Old Aug 17, 2006 | 12:06 PM
phreak's Avatar
phreak
hehehe
I was going to say the same thing. I pulled my console to do the breather tube though, so I was already in there when I ran into it.
Old Aug 17, 2006 | 01:41 PM
hd_sob's Avatar
hd_sob
I haven't done mine yet, but after looking it over, it appeared to me that all I will need to do with the breather tube is snip the zip tie holding it in place (on the outside)...Is there actually more to it than that?
THANKS!
Old Aug 17, 2006 | 01:54 PM
phreak's Avatar
phreak
ORIGINAL: hd_sob
THANKS!
There can be.
The breather tube is 3 pieces. 2 lengths of tubing, 7/16ths I think, and a philter/valve kinda deal.
You can just snip the tie, and let it ride up. I replace the tube phrom the connection on the phrame to the valve.
Old Aug 17, 2006 | 01:58 PM
hd_sob's Avatar
hd_sob
Thanks for the heads up. I'm only going up two inches, so hopefully it will not be an issue...
Old Aug 17, 2006 | 02:01 PM
phreak's Avatar
phreak
Nah, probably not. You might get away without doing anything with the breather.
Old Aug 17, 2006 | 08:05 PM
stbobber's Avatar
stbobber
I put a 3 inch on mine and all I had to change was the fuel crossover line
Old Aug 17, 2006 | 08:35 PM
zerotread's Avatar
zerotread
I've looked into these lift kits for my Wide. Is it necessary to move the fuel petcock back with the tank front elevated? Seems like the petcock would be in the dry sooner.
