Wyatt Footboard Kit?
Old Jun 6, 2010 | 07:16 PM
sm0kediver's Avatar
sm0kediver
Default Wyatt Footboard Kit?
Anyone have experience with this footboard/forward control kit?
http://www.debrix.com/Wyatt-s-Footbo...27-0920-vt.htm
Old Jun 6, 2010 | 07:18 PM
Notgrownup's Avatar
Notgrownup
Somebody posted a really bad experience with Debrix cycles today on the forum....
Old Jun 6, 2010 | 07:59 PM
sm0kediver's Avatar
sm0kediver
Any recommendations for a good footboard set up? The HD catalogue shows nothing.
Old Jun 7, 2010 | 02:35 PM
icufltrn's Avatar
icufltrn
I have the wyatt boards and really like them. I got mine off ebay for about the same price that is listed there. I think there are other dealers that sell them, i have also heard bad things about debrix. The boards were easy to put on and took about an hour. I love the way i can corner with the boards (they give you control like mids). The only thing i don't care for is I can't get my toe under to shift. If they are adjusted so I can the heel part hits the board and won't shift.
Old Jun 7, 2010 | 02:38 PM
BlockHead96's Avatar
BlockHead96
Cut the heel shifter off.
Old Jun 7, 2010 | 06:38 PM
sm0kediver's Avatar
sm0kediver
Hey thanks for the reply. I contacted Debrix, and asked for their phone # and they declined to give it, saying that they preferred to use e-mail. That puts me off a little, but they seem to have the only thing going in footboards for a Dyna. I asked about ease of installation and they responded by sending me a pdf of the instructions. It helps that you have done it and confirmed that it's pretty simple. If they can confirm that they have them in stock I may go for it.
Old Jun 7, 2010 | 07:12 PM
sigmoid's Avatar
sigmoid
I bought mine from Discount Cycle Parts (online). They were fine to deal with and the floorboards work great for me. There is no way to use the heel-toe shifter with your toe only. If that's what you want just replace it with something else. I like it personally and removed the rear shift peg and replaced it with a bolt and nuts covered with some glued together rubber grommets to make it shorter. It's still usable and now I have room for my heel back there on the board.
Old Jun 7, 2010 | 07:34 PM
sm0kediver's Avatar
sm0kediver
It sounds like it's pretty tight space between the front and back of the shifter. I test rode a HSC a while back, and I noticed that there was barely room for my #12 boot on the left side. What size shoes do yall wear?
Old Jun 8, 2010 | 12:51 AM
sigmoid's Avatar
sigmoid
I wear a 10. The distance between the front and rear peg is greater than that on the Harley shifter, but I don't know if your size 12 will fit. I had no problem with it, I just wanted another place to put my feet when riding so I shortened the rear peg a bit. It is a one piece shifter also unlike the Harley one which is 2. A lot of people change out the Harley heel/toe shifter for just a toe one, you could do that with the Wyatt boards but I haven't tried that. Do a search, someone earlier this year did that.
Old Jun 8, 2010 | 06:47 AM
Mr.Softy's Avatar
Mr.Softy
Here is a ebay link for a set I think would fit.
http://cgi.ebay.com/ebaymotors/FLOOR...item20b15af1e3
