I've read alot of threads about vibration but what I feel is more than the simple Harley vibration.
When I let go of the throttle I get this really bad shaking from what seems to be the engine. I took it to the steeler and they gave the usual "we cant make it do the same thing", even tho it happens all the time to me.
I have checked the bolts that screw from the frame to the engine mounts and they are tight but I can't seem to get to the bolts that screw the mount to the engine to check those.
Has anyone had this same prob, and if so what was it?
A friend has a '10 FB that shakes bad. Dealer worked on it. He's work on it. Vibration was reduced a little. He now thinks it may be because of the lean fuel/air ratio. He's been thinking about a SERT or other to see if it helps.
