over-shifting on downshift?
Old Aug 22, 2006 | 03:53 PM
Z's Avatar
Z
Default over-shifting on downshift?
Any of you guys had this problem? When I downshift, I often wind up in a sort of neutral position, below the gear I downshifted to. Twist the throttle and it's like I'm in neutral. Click it up once and I'm in the gear I was downshifting to. It happens most every day! I recently changed the primary fluid but it did it before the change. I measured out the proper amount of Syn3 and then visually checked to make sure it was the right level. By the way, that Syn3 crap has increased my shift effort and made it difficult at times to find neutral.
Old Aug 22, 2006 | 03:57 PM
grunt's Avatar
grunt
Default RE: over-shifting on downshift?
I have not got that, but I have heavy footed it and dropped 2 gears twice. If you have not changed riding style that could be a problem to check. My (unfixed) Hendersons did that due to a bad bushing set.
Old Aug 22, 2006 | 04:33 PM
micg1313's Avatar
micg1313
My first question would be have you recently changed fluids ? IF you added just an once to much that can happen same way if stopped and trying to get N . Next i would check all Linkage . then i would look inside for problems.
Old Aug 22, 2006 | 05:00 PM
Rhode Warrior's Avatar
Rhode Warrior
Never had that happen.
Old Aug 22, 2006 | 05:03 PM
eddybo69's Avatar
eddybo69
I ride a 87 dyna sometimes that does that b/n 5th and 4th (not sure what it is off of but the tranny has been changed)but none of the other bikes I ride or own does that.
Old Aug 22, 2006 | 06:04 PM
Z's Avatar
Z
Yep, recently changed fluids and measured the exact amount of the system, then eyeballed it to make sure the level was right. It did the same thing before the fluid change.
Old Aug 22, 2006 | 07:18 PM
mikeurig's Avatar
mikeurig
Clutch cable need adjustment?
Check behind the derby cover to see if the lock nut came loose on the adjusting rod and maybe the rod backed out.
Check the manual.
doc308
Shovelhead
Jun 6, 2019 08:44 AM
93MOOGLIDE
Sep 2, 2018 02:23 PM
Highrailer
Jun 3, 2013 04:12 PM
sifularson
Apr 14, 2008 07:16 PM
dennisaa
Feb 19, 2007 01:01 AM
