cracked fender
Old Aug 25, 2006 | 10:15 AM
ss377's Avatar
ss377
Default cracked fender
I've checked past posts, but this was not covered. What did you do with or to your old fender while you were waiting for your replacement fender? They said it would be 6-8 weeks for mine to come in. In the mean time I don't want to run without a front fender, so I have put up with the noise. Was thinking of welding the crack and putting a bandaid or sticker across the burn. Any ideas? If there is a way to keep the burned paint to a minimum, you guys would know. Thanks.
Old Aug 25, 2006 | 10:20 AM
sleepneagle's Avatar
sleepneagle
Default RE: cracked fender
yup, opposite side of where you weld, place wet towels. It will keep the burn to a minimum.
Old Aug 25, 2006 | 07:10 PM
06dynablack's Avatar
06dynablack
kept ridin mine it took 1 wk to get a black fender.mine crossed about halfways across from rear rivit on shift side.
Old Aug 25, 2006 | 09:43 PM
fireball's Avatar
fireball
Stop drill the crack. Drill a hole at the end of the crack ,this prevents the crack from migrating further. This is what we do in aviation sheet metal and this is what I have done to my previous 2 front fenders on my 06 35th DYNA.
Old Aug 25, 2006 | 10:29 PM
ss377's Avatar
ss377
Thanks for the replies guys. I think I'll try some JB Weld on it first and then weld it if that doesn't hold. Had some good results from JB Weld in the past. Don't know if it can hold up to this or not. Want to play with it until the replacement comes in. Is Black Cherry the reason I have to wait 2 months?
fireball, you had two fenders to crack? What will keep the third one from doing the same?
Old Aug 26, 2006 | 07:04 PM
fireball's Avatar
fireball
Don't know.I have wrench checked the entire front end as well as the motor mounts.I don't feel any excessive vibration.So I informed the dealer ship to get the rep involved if it happens again.The bike just turned over 10000 on the odometer.I am hopping the issue is due to manufacturing process.Has any one else experienced this problem.
Old Aug 26, 2006 | 11:08 PM
06dynablack
my dealer said he had to get the rep involved before he would warrent my 1rst cracked fender.i am hopiong i dont need another fender like you have fireball.it was almost like i damaged the fender in some sort of way with dealer grr
SOA
May 9, 2018 06:42 PM
nkauf21
Oct 4, 2014 06:07 AM
teedubya
Jun 24, 2014 12:23 PM
Robtarra39
Oct 24, 2012 08:18 PM
jambor07
Oct 3, 2008 04:03 PM
