2001 Super Glide Gas Cap Leaks
Old Aug 25, 2006 | 06:16 PM
TedH's Avatar
TedH
Default 2001 Super Glide Gas Cap Leaks
Sometimes, I fill my tank a little too full. As it is inconvenient (impossible) to dispose of the gas once it is dispensed, I have an over full tank. Fuel is usually just at the metal insert in the fuel inlet. Although, overnight, I get fuel stains running down the middle of the tank AND it warps the rubber/plastic strip that runs down the center of the tank. Is this a defective cap OR do I just need to be careful when filling the tank? I note that the gas pump will shut off when the fuel tank is full but it is often too late/too full.
Constructive criticism and advice welcome
Cheers!
Old Aug 25, 2006 | 06:49 PM
mikeurig's Avatar
mikeurig
Default RE: 2001 Super Glide Gas Cap Leaks
Best way would be to fill it by hand, don't let the pump run till it shuts off. I never do and keep looking to see how full the tank is.
Old Aug 25, 2006 | 06:52 PM
TedH's Avatar
TedH
I've gotten better at that too. Yesterday, I filled it at night and I didn't see the fuel was right there; fuel stains this morning. Got a long ride on Saturday so it won't be full much longer. I usually under-fill to be safe as I get pretty good distance on the large tank.
Old Aug 25, 2006 | 06:53 PM
TedH's Avatar
TedH
BTW, your 'Bob' looks like a close relative to my Super Glide (of course it's a Dyna). Nice lines!
Old Aug 25, 2006 | 06:55 PM
TedH's Avatar
TedH
If you ever do overfill, do you get stains on the tank?
Old Aug 25, 2006 | 07:11 PM
cj_slowdown's Avatar
cj_slowdown
<”TedH”>
<”Sometimes, I fill my tank a little too full. As it is inconvenient (impossible) to dispose of the gas once it is dispensed, I have an over full tank. Fuel is usually just at the metal insert in the fuel inlet. Although, overnight, I get fuel stains running down the middle of the tank AND it warps the rubber/plastic strip that runs down the center of the tank. Is this a defective cap OR do I just need to be careful when filling the tank? I note that the gas pump will shut off when the fuel tank is full but it is often too late/too full.”>
Do as Mikeurg states above,
Put the bike on the kick stand, (once you pay and the cap/s are off), stand the bike straight up to level, adjust legs for the hot spots
Always take off sunglasses
If the pump has one of those eviro type plungers (made for cars/trucks) on it, lift the plunger with your opposite hand, don’t just push the thing in the tank until its starts pumping, back out the nozzle (after releasing the upward plunger) to check level, now and then near the top of the fill. If you know how many miles are on the tank, in time watching the gal’s go up you will know when your near the top.
Now, take the cap off the top of the pump, twist it on, then hang up the pump handle, turn the key-on and remember to kick-back the kick-stand before you take off.
You got a 7 yr old gas cap/s gaskets, get new ones from the motor company if stock, if using a custom type make sure you know where to get re-placement gaskets.
cj
Old Aug 25, 2006 | 07:19 PM
TedH's Avatar
TedH
Chuckle. I needed to laugh. I appreciate the guidance. It helps to also have not imbibed prior to filling the tank as I have recently found.
2AMGuy
Jul 21, 2018 03:05 PM
Cafard
Apr 2, 2017 04:32 PM
labou1
Oct 4, 2012 08:19 AM
youngrider
Feb 3, 2009 09:02 AM
Beefcake
Dec 13, 2005 09:11 PM
