what do these diagnostic codes mean
Old Jul 8, 2010 | 05:39 PM
TDSnowSPR's Avatar
TDSnowSPR
Originally Posted by JRK5892
it is your injectors! it is the plugs not being on there or broken... same codes mine threw when it happend to me bud! check you injector plugs to be sure they are nice and tight, or check for cracks in the plug as well
Thanks Joe,
Gonna check it out!!!!!!!!!!!!!
Old Jul 8, 2010 | 07:16 PM
NoLongerAmember's Avatar
NoLongerAmember
Originally Posted by TDSnowSPR
Thanks folks,
Does anyone actually know what is involved in the repair of the P1004 code? I know by definition that the P1004 code states this: System Relay Contacts Closed EFI
But could someone explain in detail what this involves or what could be failing?
Thanks again,
TD
1004 is probably a bogus code. I have got the code while playing with the PCIII.
Check the wiring to the IAC for the 0505, you may have fried that circuit in the ECM or maybe a faulty IAC. It can also be set by other problems like a misfire. I would take the PCIII out of the equation, clear the codes and run the bike to see if it runs and or throws a code.
To clear the codes, when the code is displayed hold the reset switch down until the display shows "none"
CB
Old Jul 8, 2010 | 07:30 PM
TDSnowSPR's Avatar
TDSnowSPR
CB
Whats a ecm cost if that were to be the issue, And what is the IAC.
Thanks
Old Jul 8, 2010 | 07:41 PM
NoLongerAmember
Thanks
That is worst case senario. Forget I said it.
Check your ECM fuse to see if it is blown. Small blue 15A fuse, top fuse on the left hand side next to the relays. Check them all.
Time to get a service manual! And a diagnostic manual.
Old Jul 8, 2010 | 07:57 PM
TDSnowSPR's Avatar
TDSnowSPR
Thanks for your help....yeah, I agree time for a manual....
TD
Old Jul 8, 2010 | 08:09 PM
nvsteve's Avatar
nvsteve
Thanks
IAC is idle air control.
Old Jul 9, 2010 | 05:58 PM
bqualls's Avatar
bqualls
Default what do these diagnostic code mean
Here's what the Electrical Diagnostics Manual states. It's a System Relay Fault. "With the Ignition Switch turned to IGN and the Engine Stop Switch at RUN, the ECM will energize the system relay to complete the circuit to the in-tank fuel pump, ignition coil, and fuel injectors. They will remain powered as long as the engine is cranking or running, and the ECM is receiving ignition reference pulses from the CKP. If there are no reference pulses, the ECM will de-energize the system relay within 2 seconds after the Ignition Switch is turned to IGN or engine has stalled, or immediately after Ignition Switch is turned OFF."
The diagnostic tree for P1004 states:
(1) Check for poor connections, damaged terminals, poor ground or wires reversed at fuel pump. Do any of these conditions exist?
(1.1) Yes. Repair connections, terminals, grounds, and wires as necessary.
(1.2) No. Condition: fuel pump continues to run with ignition switch OFF. Remove system relay. Does pump continue to run?
(1.2.1) Yes. Replace short to voltage on (Y/GN) wire.
(1.2.2) No. Replace system relay.
Old Jul 9, 2010 | 10:18 PM
NoLongerAmember
So where are you at? Did you check the ecm fuse? Did you clear the codes? I would not focus on the 1004 code, but the 0505 and they both may be bogus.
CB
Old Jul 10, 2010 | 04:24 PM
TDSnowSPR's Avatar
TDSnowSPR
Well,
Thanks folks for all of the info!!!! We reset the codes, and they have not come back.....We found the problem to be a short in the on/off switch!!!!!!!!!!!!!!!!!
So far so good!
Thanks again everyone,
TD
Old Jul 10, 2010 | 04:39 PM
Dynamic's Avatar
Dynamic
How did the short occur? Was it the switch (handlebar?) or the wiring?
