what do these diagnostic codes mean
Old Jul 7, 2010 | 01:12 PM
TDSnowSPR's Avatar
TDSnowSPR
Default what do these diagnostic codes mean
P0505 and P1004
These are the codes that popped up,your help is appreciated
Thanks
Old Jul 7, 2010 | 01:34 PM
trip20's Avatar
trip20
P0505: Loss of Idle Speed Control E
P1004: System Relay Contacts Closed EFI
Found here.
Old Jul 7, 2010 | 01:37 PM
TDSnowSPR's Avatar
TDSnowSPR
Found here.
Thanks,
Any idea where to go from here
My bike is running like crap....spitting sputtering, idle very high....
Old Jul 7, 2010 | 02:04 PM
trip20's Avatar
trip20
I know there are a few sensors associated with Idle Speed Control and such so you may want to begin with replacing them. If you have a service manual you can look those sensors up to get an idea of where they are, how to remove them, and how to replace them.
The System Relay message I have no idea on that, sorry.
People will swing in here eventually and give you good info.
I'll be in Balmer this Saturday..... glad I missed the 105 degree week you're having!
Old Jul 7, 2010 | 03:21 PM
TDSnowSPR's Avatar
TDSnowSPR
Thank you!!!!!!!!!!
Old Jul 7, 2010 | 04:53 PM
JRK5892's Avatar
JRK5892
Old Jul 8, 2010 | 03:53 PM
TDSnowSPR's Avatar
TDSnowSPR
Any other ideas what P1004 is.
Thanks,
Sean
Old Jul 8, 2010 | 04:30 PM
Wonkaboy's Avatar
Wonkaboy
Thanks,
Sean
P1004 System Relay Contacts Closed EFI
Check out this site for codes
http://www.harleyhelp.com/troublecodes.html
Old Jul 8, 2010 | 04:44 PM
TDSnowSPR's Avatar
TDSnowSPR
Thanks folks,
Does anyone actually know what is involved in the repair of the P1004 code? I know by definition that the P1004 code states this: System Relay Contacts Closed EFI
But could someone explain in detail what this involves or what could be failing?
Thanks again,
TD
Old Jul 8, 2010 | 05:21 PM
JRK5892's Avatar
JRK5892
it is your injectors! it is the plugs not being on there or broken... same codes mine threw when it happend to me bud! check you injector plugs to be sure they are nice and tight, or check for cracks in the plug as well
