HELP! lost brake lights and turn signals
Old Jul 10, 2010 | 11:24 AM
AstroGlide's Avatar
AstroGlide
Default HELP! lost brake lights and turn signals
08 FXDC...Panacea tail with stock signals removed. The taillight still works because it flashes the signals and the brake light if I shake the bike without my fob close by. I get no brake light from either the lever or the foot brake. No signals from each side by using the turn signal buttons. I found no visibly blown fuses or pinched wires. I'm thinking relay but I really have no idea. Any ideas? Thanks for the help guys
Old Jul 10, 2010 | 11:29 AM
Grendel4's Avatar
Grendel4
Isn't the Panacea line LED? If so, did you use a Load Equalizer?
P.S. Does your bike have a Factory alarm? If so, you may need an alarm specific Load Equalizer.
P.P.S. Tail lights are not load dependent.
Old Jul 10, 2010 | 11:35 AM
ratt196635's Avatar
ratt196635
I have had the Panacea tail light with out a load Equalizer for two years with out any problems.
Old Jul 10, 2010 | 11:38 AM
Grendel4's Avatar
Grendel4
My bad. It took me a coupla minutes to edit and add: Tail lights are NOT load dependent. Turn signals are.
Old Jul 10, 2010 | 04:00 PM
AstroGlide's Avatar
AstroGlide
Default No Brake light
I do have the factory alarm but I have had this tailight installed for 4 months with and without a load equalizer and it has worked as it should. I swapped both relays from a same year Dyna at work today and that didnt work either. I also tried changing the taillight base thinking the circuit board behind the taillight was bad but still no dice. I have done some mods to my bike including removing the dash/speedo and installing a three way toggle switch in place of the factory on switch. I wiggled/checked all my connections and still nada. I did not cut either of the two harness plugs that connect to the speedo/dash lights. the ONLY splicing i have done is lengthen the three wires to the toggle switch mounted behind my...(its hidden for a reason=) If I cleared my error codes would that maybe do it? grasping at straws here and not in a position to take it to a shop.
Old Jul 12, 2010 | 09:21 AM
AstroGlide's Avatar
AstroGlide
Default No brake lights
Looks like the "heavy duty" toggle switch I installed didnt live up to its name. the on side of the switch went bad but the bike would still start. strange. I reinstalled the stock HD switch and all is well.
Old Jul 12, 2010 | 10:14 AM
Grendel4's Avatar
Grendel4
Thanks for letting us know the cure.
Interesting.
tmultra
Apr 12, 2018 08:57 PM
213_LooseNoodle
Jun 1, 2016 01:28 AM
tmultra
Mar 16, 2016 03:17 AM
mikewardlaw
May 1, 2012 06:43 AM
fenderzig
Apr 15, 2012 09:43 PM
