Dyna Shocks
Old Jul 11, 2010 | 03:24 PM
Papa Bear's Avatar
Papa Bear
Default Dyna Shocks
Please excuse my ignorance, but is there any rear shock adjustment possible on a 2007 FXDC?......... when two up, my bike bottoms out too easily and speed humps can be a pain in the butt.
If not, what rear shock is recommended?
Old Jul 11, 2010 | 03:32 PM
wild one's Avatar
wild one
I have a 07 & mine are adjustable.
wild one
Old Jul 11, 2010 | 03:35 PM
zitman11's Avatar
zitman11
They should be adjustable...you just need the spanner wrench...
There will be a label on the shock itself that show the adjustments from 1 to 5...
Old Jul 11, 2010 | 04:20 PM
ord sgt's Avatar
ord sgt
The holes at the bottom of the outer shock tube are the points to place the wrench. Adjust by the amount of clicks. H-D has a shock wrench, as do others.
Old Jul 11, 2010 | 04:59 PM
dyna rider's Avatar
dyna rider
Default Adjustment
You can use a strap wrench to adjust them. 1-5 lower number is softer.
Old Jul 11, 2010 | 05:08 PM
08fxdf43202's Avatar
08fxdf43202
Spring Pre-Load Adjustment
Old Jul 11, 2010 | 08:41 PM
wideglidebob's Avatar
wideglidebob
i suggest a strap wrench so mush more easier to adj those cheapo shock spanders are a bitch
Old Jul 11, 2010 | 11:34 PM
goblin127's Avatar
goblin127
I'm able to do it with a gloved hand.
Old Jul 13, 2010 | 06:31 AM
Papa Bear's Avatar
Papa Bear
Thanks for all the replies - now I look more closely, I can see the levels of adjustment. Will try using a strap wrench on them tonight.
Cheers!
FXSTD.AU
May 3, 2018 02:30 PM
Lingleha
Jul 5, 2012 09:09 AM
BluBob
May 3, 2008 11:32 AM
FXDL Dave
Aug 29, 2007 11:41 AM
MARCUSBEAR
Jul 13, 2007 12:03 PM
