Base Dyno Run...
Old Jul 14, 2010 | 06:35 PM
FXDFan's Avatar
FXDFan
Default Base Dyno Run...
Numbers came back from a baseline run, cams go in tomorrow and dyno tune Friday...
Scanner is piled up so can't post the sheet ( new scanner coming in a day or so, will post both before/after then ).
Bike is 08 FatBob with V&H BR 2-2, RSD a/c, and PCV with fuel moto satage 1 download.
Here's what's on the sheet;
Correction factor : SAE Smoothing 5
5th gear run
62*celsius
29.01 in-Hg
Humidity 57%
SAE 1.26
Results ended up a lot higher than I thought, or think it should be :
82.71 hp at 5000 rpm 100.46 tq at 3600 rpm
My guess before the runs were 70 / 80 or 85. Any guesses or insight why it's so high? Guess so long as I get the same dyno operator he should run it the same so I can get an idea on how big a difference the cams are going to make ( TW6-6).
G.
Old Jul 14, 2010 | 07:27 PM
thedonthere's Avatar
thedonthere
too high 62* celcius = 144* fahrenheit are you sure about that number?????
Old Jul 14, 2010 | 07:41 PM
FXDFan's Avatar
FXDFan
That's what it says on the dyno sheet, kinda thinking that's engine temp, definitely not ambient temp
Old Jul 14, 2010 | 07:49 PM
paul s's Avatar
paul s
Mine was 70hp/83tq with Sideshots,T-Max and a K&N. It took cams, porting and a compression bump for me to get over 100.
Old Jul 14, 2010 | 08:04 PM
FXDFan's Avatar
FXDFan
Ya it just seems way high, that's why I posted, numbers just don't seem accurate to me. Not sure if I posted earlier but our elevation is 1100 feet, although the correction factor should be takiung that into account..
Old Jul 14, 2010 | 08:24 PM
MarineMike's Avatar
MarineMike
I need to find my dyno sheet, but what I can remember is I hit 77hp with a stage one kit, SEII slipons stock engine. I thought that was not bad.
Old Jul 14, 2010 | 09:56 PM
dope_man_21's Avatar
dope_man_21
I dunno, but I thought that the SAE setting was suspose to be set at 1.00 As said I don't know, but that is where mine was at, maybe someone who know exactly what that number references can chime in.
Old Jul 14, 2010 | 11:09 PM
red devil's Avatar
red devil
Yeah something doesn't sound right. The hp seems a little high, but it could happen, but 100tq? I don't know if thats ever been done before with just a stage 1. I guess you'll see on friday, either your tq will be up in the teens or it's going to stay the same. If it stays the same, something isn't right.
Old Jul 15, 2010 | 12:25 AM
tab69pr's Avatar
tab69pr
its high cause you ran a 5th gear run on...make 4th gear run on for true HP, TQ runs....
Old Jul 15, 2010 | 01:12 PM
FXDFan's Avatar
FXDFan
I thought it was 4th gear for 5 speeds and 5th for 6 speeds?? Been confused before... No biggie, I only wanted to see a before and after run to see what kind of improvement the cams will make. Just have to make sure it gets run in 5th gear again to keep it consistent.
