Base Dyno Run...
Old Jul 15, 2010 | 01:31 PM
Grendel4's Avatar
Grendel4
Looks to me like the black box 'Weather Station' on the dyno was picking up 62 degrees celsius for some reason or another. Exhaust? Whatever. Prolly needs calibrated.
But the computer on the dyno will automatically correct the power reading (Power Correction Reading) to what it would have been at STP (Standard Temperature Pressure) based on what the Weather Station is telling it. Which is 29.92 inches of mercury and 60 degrees Fahrenheit.
Just a guess. But based on this --
Here's what's on the sheet;
Correction factor : SAE Smoothing 5
5th gear run
62*celsius
29.01 in-Hg
Humidity 57%
SAE 1.26
Results ended up a lot higher than I thought, or think it should be :
82.71 hp at 5000 rpm 100.46 tq at 3600 rpm
I'd say the Correction factor being used is 1.26 so if you divide 82.71 by 1.26 you get 65.6 on HP and 100.46/1.26 would give you 79.73 lb-ft of torque, both at STP.
Just a guess. But it sounds right.
Old Jul 15, 2010 | 04:15 PM
dope_man_21's Avatar
dope_man_21
5th gear run
62*celsius
29.01 in-Hg
Humidity 57%
SAE 1.26
That is what I was thinking as well, but was not sure, but it sounded logical.
Old Jul 15, 2010 | 05:42 PM
FXDFan's Avatar
FXDFan
That's very possible. My guess before it went on was 70hp / 85 or 90 tq, so was very skeptical to see the #'s it posted. Time will tell, cams are in now, just home from the dealer, seat of pants says it is definitely stronger, guess we'll have to wait til tomorrow to see just how much
Old Jul 15, 2010 | 06:58 PM
blacknsilver's Avatar
blacknsilver
Here is my Fatbob results with a stage one setup. 70.12 hp / 78.10 tq
Boyer8
Sep 10, 2013 05:42 AM
mgmmgm
Jul 24, 2013 08:55 PM
RoadKingGibson
Exhaust System Topics
34
Jan 19, 2012 11:03 AM
harris48cars
Aug 4, 2010 12:57 PM
oscarg
Apr 20, 2010 10:25 AM
