Stage 1 Recalibration FACTS inside
Old Jul 23, 2010 | 05:31 PM
  #41
jstreet0204's Avatar
jstreet0204
Originally Posted by jinx44
NBO2s don not even have enough range to read the AFR at WOT, so how could they come into play to adjust values?
Because the apative ability isn't based off the NBO2 value. It is based off the the amount of fuel the ECM had to add or take away to get reach the targeted voltage of the NBO2. Those values are stored in memory and adjustments are made to final fuel calulations.
Old Jul 23, 2010 | 05:58 PM
  #42
HBomb74's Avatar
HBomb74
sorry, still confused as hell. i am just gonna save my pennies and by a powercommander V
Old Jul 23, 2010 | 06:07 PM
  #43
joflewbyu2's Avatar
joflewbyu2
Old Jul 24, 2010 | 03:54 AM
  #44
Foxster's Avatar
Foxster
A think there is a bunch of confusion around what the EFI system can and cannot cope with in terms of hardware changes. My only input to this is that I understand something fundamental changed in '09.
Prior to '09 its fair to say there is a body of measured evidence that if you put on a high-flow A/C and pipes with no adjustment to the EFI then the AFR shifted to leaner; typically the closed-loop AFR at certain loads/RPMs shifted from around 14.6/14.7:1 to 15:1 or leaner, depending on the hardware used. Similar changes occured to open-loop.
Since '09, however, something changed. I dunno what but two HD dealers told me that stage-1 downloads are no longer needed on new bikes; you can put an SE A/C and SE mufflers on and the EFI will manage the change. Now, if these dealers had said the opposite, that more money needs to be spent, I'd be cynical, but these people are saying that you don't have to spend the extra on the stage-1 download as it adds nothing i.e. you will end up with the same EPA-compliant AFRs as before. This might not be great from a stage-1 perspective and you will be leaving power on the table but it does imply you won't be doing any harm either.
I dunno what changed though. Different software, different sensors, different ECU completely, all three?
Old Jul 24, 2010 | 06:08 PM
  #45
srshaw's Avatar
srshaw
Thats interesting. I want to add a heavy breather to my '10 Fat bob. To be honest its for the looks, the bike is fine as it is in terms of performance. There seems to be no real consensus as to whether a tuner would be needed or not but perhaps I'm more leaning towards the fact that one isn't necessary. The annoying thing is that even dealers don't agree and say different things. One told me my Rush slip ons wouldnt work without full stage one with tuner (they work fine) and another said it would be fine to add an air filter, but a tuner would get more power. Who knows???
Old Jul 24, 2010 | 07:42 PM
  #46
Just Enough's Avatar
Just Enough
I feel that stage 1 upgrades, air cleaner and mufflers don't change the volume of air that the 96 can pump enough to necessitate a open loop power enrichment change. The twin cam motor is limited mostly by cam and head flow, stage one upgrades might add 5% to 8%. Under closed loop the system can definately compensate for stage 1 with the O2 sensor fuel trims. Under open loop the factory calibration is a safely rich mixture that will also support stage 1 upgrades unless you are doing something totally extreme with your bike like towing a trailer up a mountain grade wide open for 10 minutes at a time or running 87 octane. Once you significantly change the air that the engine can pump either with a displacement change, cam change or head work the open loop power enrichment and closed loop VE tables need to be altered for safe running.
Old Jul 24, 2010 | 08:15 PM
  #47
nvsteve's Avatar
nvsteve
And will still run too lean and too hot.
Old Jul 24, 2010 | 09:03 PM
  #48
Just Enough
Xieds are the cheap, easy and safe way to deal with cooling down a stock and stage 1 bike.
Old Jul 25, 2010 | 07:49 AM
  #49
nvsteve's Avatar
nvsteve
Many riders are happy with them. I wonder if they add enough fuel to cool sufficiently?
Old Jul 25, 2010 | 08:12 AM
  #50
HBomb74's Avatar
HBomb74
wow, never thought there would be so much of a difference of opinions/facts. What's a newbie like me to do?? I'm just gonna save my pennies for the whole shebang at once. A/C, pipes, PC V
