Do you have a bullet headlight?
Old Sep 9, 2010 | 08:02 PM
Streets of Fire's Avatar
Streets of Fire
sorry for the quality... I haven't seen my bike in the daylight in a few days... Tommorrow I will when I ride to work on my birthday in Cleveland!!!!
Old Sep 10, 2010 | 06:39 AM
0lowrider1's Avatar
0lowrider1
i really like the look of the bullet headlight...but was wondering if the light assembly bounced around any..?you know when you hit a bump does it kinda flop around...i am lookin to do this to my 01 fxdl....
Old Sep 10, 2010 | 07:15 AM
Streets of Fire
Mine doesn't move at all.
Old Sep 10, 2010 | 10:39 AM
maryland blackout's Avatar
maryland blackout
Streets, thanks for all the help and Happy Birthday! That piece looks like it will do the job nicely and definitely a good idea to bundle those wires. That's a clean look you've got there considering what it starts out looking like.
Old Sep 10, 2010 | 11:12 AM
TattoodCaptain's Avatar
TattoodCaptain
I did it too mine too. Like it a lot better.
Old Sep 10, 2010 | 11:39 AM
JRK5892's Avatar
JRK5892
mine is in my sig picture, it used to move around so i made a new plate for the inside of the lamp to move the pressure out a bit instead of just though the bolts, worked great, also tossed the HID in there while it was open... best move i have done in a while on the bike!
Old Sep 10, 2010 | 02:10 PM
maryland blackout
Originally Posted by Streets of Fire
To clean up the top tree I bought a piece from Headwinds which also allowed me to install the dummy lights there. All in all it came out clean. Not as custom as some others but clean.
http://www.headwinds.com/mm5/merchan...ry_Code=010502
So i contacted a guy at headwinds to get some details about the two top tree options available i.e the smaller cover which everyone seems to use: part # 6-0005-2CA vs the shield cover which hangs between the forks: part# 6-0006CA. He sent me these pictures of the installed pieces from customers bikes. the smaller one has a medallion added on to it but these were two good looks at an end result. I wanted to put them up because it seems no-one has the large shield pice.
Old Sep 10, 2010 | 02:15 PM
maryland blackout
And here is the shield part# 006CA
Old Sep 20, 2010 | 09:16 AM
maryland blackout
Default of course...
well i got the top tree cover and of course it doesn't fit. The wires from my speedo (which is on the handlebars) go straight down in front of the top tree and the cover is a full cover for this area so there is no clearance for the wires. I am going to have to find a buddy with a tool that can cut the metal cover to allow clearance for the wires behind it and then go ahead with the install. Until then, i just zip-tied all of the wiring to clean up the look. Geez there seems to a lot of excess wire length on the bike. All of the excess is kind of folded up in a ball on the left side of the neck. Oh well, it's slowly getting a little better with each step.
Old Mar 24, 2013 | 11:23 AM
Hulse88's Avatar
Hulse88
Stage II
What mounting bracket are you all using to mount the Cobra 2 headlight?
I'm trying to mount it on a 2002 night train and its way to long for the stock mount setup.
Any help would be great!
