I know I just want to find out what the diff is. If you use wide glide trees. Can you just use the FXDC sliders an shim the brake caliber.
Yes, read the bold text below:
Originally Posted by WS6 Formula
Here's what I used: 2006 Wide Glide parts; 21" wheel, upper and lower triple clamps, axle, axle spacers.
From a hardware store: 3/4" spacers and 3/4" longer stainless Allen head bolts for mounting the fender, and stainless washers for shimming (.040" for the caliper & .090" for the rotor) to center the caliper over the rotor.
Use other existing hardware from your bike (axle nut and washer, triple clamp pinch bolts, head bearings nuts and washer, fender nuts, forks, etc.).
I bought the parts from Zanotti's back in June of 06.
Here are the Harley Davidson part numbers and Zanotti prices:
P/N 46700-06 Upper Triple Clamp.....$ 65.75
P/N 46386-06 Lower Triple Clamp....$139.83
P/N 40923-06 Front Axle..................$ 28.39
P/N 40926-06 RH/FRT Spacer.............$ 4.58
P/N 40927-06 LH/FRT Spacer.............$ 4.58
Total..$243.13
Update: 4/3/08 Axle spacers above are also available in a chrome tapered version P/N 41410-06 Chrome Tapered Front Wheel Spacer Kit $23.51
Original Wide Glide tire replaced with only 7,300 miles on it (Not much tread left). Replaced it with a Avon Venom AM41 90/90-21, widest tire (3.70") I could find that will fit the Wide Glide Profile rim.
